First post, by Unregistered
is it possible to map the signal for fm synthesis, ( from either an adlib or sb synth map ) to the wavetable synthesis on the card, rather than having to use the mt32-gm setting... ( some sounds just arent right with the mt32 conversion)
Reply 1 of 2, by Nicht Sehr Gut
Originally posted by Unregistered is it possible to map the signal for fm synthesis, ... to use the mt32-gm setting...
No. I'll leave it to the MIDI experts to explain this.
Reply 2 of 2, by Snover
Here's the simple, VDMSound explanation:
VDMS renders the OPL3/AdLib audio as a wave, whereas MIDI (GM/GS, MT-32) is sent to your card. OPL3/AdLib also does some things that aren't possible in any MIDI implementation.
Closing thread: NOPE (though, Vlad, feel free to respond -- and try to make it look like I'm not a complete dumbass 😉)
Yes, it’s my fault.
