Procyon wrote on 2023-12-10, 09:29:
I'm trying to get Zuma's Revenge running in 4:3 on my 2560x1080 monitor but none of the scaling options seem to work so I get a stretched screen.
I can get 4:3 whenever I choose 1280x1024 but it looks kind of bad so I wonder if it's possible to choose 1440x1080 resolution some way.
It's strange that 'Stretched, keep aspect ratio' does not for you work in regard of the appearance, it should.
The only exception is if the game sets the resolution itself (so that, changes the desktop resolution) before dgVoodoo is activated then you're out of luck.
Anyway, you can either force a custom resolution by adding one to DirectX\Resolution, or you can specify a custom application resolution by adding it to DirectXExt\ExtraEnumeratedResolutions and select it from the application if it supports that particular resolution. You can do that even from the Cpl.
But I think this is mentioned in the readme.
