First post, by Shamatic
First time poster, long time lurker here.
The reason I'm posting here is because I've been working on a project that might spark your interest.
Background: So, on a long night I was looking at some old schematics about a PWM Covox implemented in TTL and an idea struck me that an Atmega328 would totally capable to do the same thing and more. And it seemed to be an easy thing to implement. Since I had some Pro Minis at hand, I started to work on it almost right away (I mean in a few days). Now that easy thing turned me to learn AVR assembly (I had no assembly knowledge before at all) to control as much aspect of the MCU as possible to make this contraption work. I hope you think I succeeded my task.
Here is a photo of the completed device:
file.php?mode=view&id=180595
This thing has a lot going for it:
  • It's the simplest and the cheapest in it's category, only a few parts to build. And also the smallest, as the whole design can fit in an LPT connector housing.
  • Fully working DSS with proper auto-detection support. (Tested in Wolfenstein 3D, Alone in the Dark, Dungeon Master.)
  • Stereo-in-1 mode supporting multiple kinds of signaling modes. (Tested to work with Inertia Player, ModPlay Pro, Dual Module Player, Galaxy Music Player and Crystal Dreams.)
  • Mono Covox plays on both channels.
  • Fully automatic, properly switches to the exact state it needs to be, no matter what garbage others leave on the LPT's control port.
  • MCU code is written in AVR Assembly, uses 266 bytes of flash and 16 bytes of ram (for the DSS fifo buffer) and it's interrupt driven.
Hereby I attach a package of code and instructions if you wish to build it yourself and give it a test run. I would appreciate any feedback if you did.
AVRSnd 0.5b
PS: I know this setup has it's limits in the sound quality department, but I'm already contemplating about porting this code to the STM32 bluepill, which has I2S output, can be programmed on the low level, not to mention being faster. Also (as far as I know) it has enough ports to emulate a dual lpt setup too, so that would be some added bonus too. Sadly my only Bluepill is in my homemade Unamiga clone, so this will have to wait until I order some, and have both the motivation and the time to do the porting. (This can amount to a surpisingly long amount of time, as I'm lazy.)
Edit: Fixed the bug of Modplay and Galaxy Player is playing in reverse
Reply 1 of 12, by wbc
sounds very promising, I once built a similar PWM stereo Covox on a EPM3032 CPLD, and it sounded way better than any R-2R based DACs I've tried, and now this one loks like an ultimate and cheap Covox solution! looking forward for the updates, and would be nice to have a PCB schematic to make building easier :)
--wbcbz7
Reply 2 of 12, by Jo22
Wow, that's cramped! I'll never challenge you at a game of Tetris or Columns! 😁
Seriously though, fine work! Congrats!
Reply 3 of 12, by CODOR
Nice! I've been working on something similar on and off (mostly off) for a while now except it lives on a solderless breadboard so it's way bigger (and I'm using through-hole parts so it's unlikely to fit in a D-sub shell). Mono COVOX and Stereo-on-1 work on mine but there's no autodetect code yet. DSS doesn't work; looking at your code I think I may have reversed the sense of the ACK pin 😜
Reply 4 of 12, by matze79
https://github.com/matze79/McRat
edit: github now public
The attachment mcrat.jpg is no longer available
I tried to make a PCB version, but unfortunately it doesn’t work.
My test program shows that both PWM channels output audio correctly.
The device is only detected sometimes (DSS), and there is no Covox or DSS output at all.
Maybe some pull-ups or other adjustments are needed.
For testing, I used a 25 MHz oscillator. The clock divider is disabled and fusebits are correct, and the oscilloscope shows the correct clock.
(22.x MHz oscillators are less common, but they can be ordered from Reichelt.)
Have you ever tested it with a 25 MHz oscillator?
In the version shown in the photo, the audio jack is soldered one pin row off because I used the wrong symbol and didn’t notice it.
This has already been corrected in the PCB files on github.
I compared all the pins several times and couldn’t spot any mistakes yet.
my i dig deeper, when i have time again.
Thanks!
Reply 5 of 12, by dr.zeissler
I am currently using several different devices over LPT-Switchbox in order to have sound on my PS2/E.
What do you think is the best LPT-Device to get most out of one LPT-Device?
Where can I place an order for those/these devices ?
LPT-Switchbox (currently)
1. OPL3LPT
2. COVOX
3. DSS
4. free
RS232 (planned)
- something that let's me play MT32 Games.
Reply 6 of 12, by jansakos
dr.zeissler wrote on 2026-02-27, 08:28:
I am currently using several different devices over LPT-Switchbox in order to have sound on my PS2/E. What do you think is the b […]
1. OPL3LPT
2. COVOX
3. DSS
4. free
RS232 (planned)
Greetings,
From my research for the Picovox project, I believe you already have the most useful devices available. Apart from the ones you have already mentioned, there is also the FTL Sound Adapter (as far as I know it is supported by only a single game, and Covox can be modified to be compatible with it), Stereo-on-1 (a pretty cool device, although its support is quite limited; essentially a Covox with stereo capabilities), CMSLPT (using the same chips as the Game Blaster, supported by roughly a hundred games), and TNDLPT (which is not particularly interesting).
There are also several sound cards primarily supported under Windows rather than DOS (such as the Logitech AudioMan). The only notable exception is the Digispeech Plus DS311, which can emulate a Sound Blaster — although finding this device today is extremely difficult.
Reply 7 of 12, by carlostex
jansakos wrote on 2026-03-05, 20:55:
(...) TNDLPT (which is not particularly interesting).
Wondering why you have this opinion. Tandy sound is in a lot of games for PC (older classics) the best sound option available.
Reply 8 of 12, by jansakos
carlostex wrote on 2026-03-06, 18:24:
I have at least two reasons for this. The first is that many games refuse to work with TNDLPT because they do not detect the Tandy device directly; instead, they check for the presence of Tandy hardware in the BIOS, which, as far as I know, this driver does not bypass. The second reason is that software emulation of this standard (e.g., TEMU running on Covox) is not significantly different from the real chip.
Reply 9 of 12, by carlostex
jansakos wrote on 2026-03-06, 23:38:
Well the TN SN76489 / NCR 8496 chips are write only so the chip cannot be detected directly. Game developers, for the PCjr and the Tandy 1000 had to have a way to detect which machine the game was running on. Coding a selectable option for tandy / pcjr was more labor intensive. Drivers cannot bypass any detection, so the detection has to be defeated in order to get Tandy sound. This is true for TNDLPT or any Tandy sound cards. I know this because i patched the majority of games so they can be played on a non Tandy system with a Tandy sound card or TNDLPT. Patching for TNDLPT is a little bit more complicated because outputting data to the LPT port you can't just do a simple OUT instruction. In any case, i already did some stuff for the Serdaco TNDLPT including patched AGI interpreters that talk directly to the TNDLPT without need for redirection. I also created a specific TNDLPT driver for Audio Interface Library 2 by John Miles. A device with a MCU that could handle all the LPT port handshaking and such could eventually used my patched binaries that enables a 2 byte output instruction for a homebrew Tandy sound card.
As far as TEMU emulation for Covox, i'll disagree with you, not to mention that this emulation might bring another problems during runtime on whatever game you're trying to run.
But anyway, TNDLPT or no TNDLPT, the device you're working on is interesting enough.
Reply 10 of 12, by dr.zeissler
Greetings, […]
1. OPL3LPT
2. COVOX
3. DSS
4. free
RS232 (planned)
Greetings,
Thank you. How do these Windows-Sounddevices work (e.g. AudioMan) ? Covox and OPL3LPT do not offer windows-drivers that really work and do not interrupt the machine while use. There are also soundcards (ess) adapted to the IDE-bus wired/connected to LPT on these external LPT-CD-ROM's that "backpack" offered in the 90's and early 2000's. Are there any projects to recreate these? The only thing I really need would be for Win3x/9x and OS/2.
Reply 11 of 12, by terryfi
matze79 wrote on 2025-11-29, 12:34:
h
ATMEGA318P maximum clock is 20 MHz, did you try 20 MHz first?
TerryFi
Reply 12 of 12, by matze79
terryfi wrote on 2026-04-20, 21:48:
h
TerryFi
I wrote a testprogram outputting some test sounds on both pwm channels, so mcu is running fine at 25 Mhz.
I did not investigate any further for now.
