First post, by ala_borbe
hi guys,
i was hoping that someone here has this or a similar card in their possession.
i have acquired pci radeon 7000 Sun Microsystem version in mint condition, but upon inspection, I have discovered that two components are missing.
According to this image online, it is a 3-leg component next to a 0 ohm resistor (SMD).
http://www.512bit.net/ati/hi/ati_radeon_7000ddr_6.jpg
Looking at the nearby component and assuming it is the same part, it looks like there is "2MLV" written on it, but it is very faint, and I am not sure that these are the markings.
Googling this part did not get me a datasheet, so I still don't know what the component is. assuming it is some voltage regulator.
    1.24 MiB
    853.63 KiB
    784.94 KiB
Reply 1 of 5, by Tiido
I have this card somewhere, but my first search turned up empty and now I have a mountain of cards all over the place 🤣. I will still attempt to uncover it after I sort through the mess I made.
It possibly is a voltage regulator but it may be a simpler component too.
Reply 3 of 5, by ala_borbe
thanks for your clarification. i have managed to source schematic for agp radeon 7000 and that part code is confirmed.
checking my stack of broken cards to see if i have compatible part. if not, i will order some.
