First post, by DosGamePlayer
Whenever I try to play Lemmings3D it starts up saying that there was a EFFECTS DRIVER ERROR: SOUND EFFECTS DISABLED. I set it to Soundblaster which was the only option that was compatible and you couldnt set anything else up. Plus during play the sound will dissapear and if you were to kill NTVDM then it would come back. Whats going on?
Reply 1 of 2, by eL_PuSHeR
Judging from another post of yours, I think you may have different Port, IRQ, DMA settings under VDMSound when compared to the games you are trying to run.
Right-click on the .VLP shortcut (for VDMSound) and compare SB settings to match those in the game.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
