First post, by vvbee
On GitHub: https://github.com/leikareipa/w95-distrib
Reply 1 of 6, by DerBaum
Thats pretty cool 😁
FCKGW-RHQQ2
Reply 2 of 6, by vvbee
It's also possible to integrate DOSBox into the UI relatively seamlessly by painting a hole in the canvas with a transparent widget, composing it with the DOM element of jsdos underneath and doing some dynamic redirecting of mouse and keyboard events. The animation is from a year ago when I did a test implementation. The w95 UI now uses multiple canvases rather than one so this doesn't work directly, but probably can be adapted.
Reply 4 of 6, by vvbee
Proper DOSBox integration works more or less. Sort of pointless though. I guess you could build a web app with this that takes in a ZIP of a DOS game, displays the files in an explorer, and runs the exes in DOSBox, for what it's worth. A bit roundabout.
Reply 5 of 6, by StriderTR
I have to echo.... this is cool!
I will be playing with this very soon. 😀
Thanks for posting!
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 6 of 6, by vvbee
The framework is now in post-beta, with various changes. It's now closed-source with an open distributable. You can report bugs to the distrib repo.
You can feed the manual to Google AI Studio and have it build apps to spec:
The attachment nameque.png is no longer available
GPT-4o is better at reconstructing UIs from mockup sketches, but the free version on ChatGPT doesn't have a large enough context window for the full manual.
