First post, by songoffall
Rig 1:
  • CPU: Athlon XP2000+
  • RAM: 512Mb DDR
  • GPU: GeForce 4 MX440
  • Sound: Creative Audigy 2
  • OS: Win 98SE
Rig 2:
  • CPU: Intel Pentium 4 HT 3.0GHz
  • RAM: 512Mb DDR
  • GPU: GeForce FX 5500
  • OS: Win 98SE
Rig 3:
  • CPU: Intel Pentium III 733MHz Coppermine
  • RAM: 512Mb PC133 SDRAM
  • GPU: 3DFX Voodoo3 3000
  • Sound: Diamond Monster 3D Sound MX300 (Aureal Vortex 2)
  • OS: Win 98SE
This is a list of GOG games I tested on Win 98SE, and fixes to make them work when applicable.
  • Aliens vs Predator FAILURE
  • Anachronox SUCCESS / FIX FOR 3DFX CARDS
    While the game did work on Voodoo3 3000, the performance was less than stellar. The fix is the following: - Install a registered […]
    - Install a registered version of WickedGL
    - Instead of using the included utility, copy the OpenGL32.dll from Program Files\Metabytes\WickedGL, paste it into Anachronox install folder
    - In Anachronox install directory, go into Anoxdata\SAVE\GLOBAL and open settings.cfg
    - Edit the last line saying "set gl_driver" to the following: set gl_driver "opengl32"
    After these steps Anachronox should perform as expected.
  • Arcanum FAILURE
  • Baldur's Gate The Original Saga SUCCESS
  • Baldur's Gate 2 SUCCESS
  • Blood Omen: Legacy of Kain FAILURE
  • Blood Omen 2 SUCCESS
  • Clive Barker's Undying SUCCESS / FIX FOR 3DFX CARDS
    On 3dfx Voodoo3 3000, the same solution as with DeusEx applies. Remove the following files from the game's installation folder: […]
    glide.dll
    glide2x.dll
    glide3x.dll
  • Commandos: Behind Enemy Lines SUCCESS
    Commandos and its expansion Beyond the Call of Duty freeze your system if you have K-Lite Codec Pack installed. Black screen, audio plays, nothing else works except for a hard reset.
  • Commandos: Beyond the Call of Duty SUCCESS
    See above.
  • Commandos 2: Men of Courage SUCCESS
  • Deus Ex SUCCESS / FIX FOR 3DFX CARDS
    The game would freeze in 3dfx Glide mode on real 3dfx Voodoo3 3000 AGP. The fix is to remove the following files in the System f […]
    The game would freeze in 3dfx Glide mode on real 3dfx Voodoo3 3000 AGP. The fix is to remove the following files in the System folder:
    glide.dll
    glide2x.dll
    glide3x.dll
  • Diablo SUCCESS
    GrampaGotTheKeys wrote on 2019-03-24, 21:11:
    SEMI-FUNCTIONAL: Diablo setup_diablo_1.09_(27873).exe Single player working - but you need to move the "Diabdat.mpq" from the ma […]
    SEMI-FUNCTIONAL:
    Diablo
    Single player working - but you need to move the "Diabdat.mpq" from the main folder to the "/dx" folder and set up a shortcut to the Diablo.exe from the "/dx" folder to play
    Trying to start multiplayer breaks the game
  • Divine Divinity FAILURE
  • Dungeon Keeper Gold - SUCCESS-ish
    It installs with DOSBOX, extracting and running the game image is easy enough. Running through DOSBOX is a torture on older PCs.
  • Dungeon Keeper 2 SUCCESS
    The DKII-DX.EXE file in the GOG shortcut has horrible performance, but the DKII.EXE works just fine.
  • Fallout SUCCESS
    Don't use the GOG-provided launcher, just use the falloutw.exe instead.
  • Fallout 2 SUCCESS
    Same as above, use fallout2.exe instead of the launcher.
  • Giants Citizen Kabuto SUCCESS
    Doesn't work out of the box, but is fixable. GOG.com support provides with two alternate versions of gg_dx7r.dll, the one in the DX7 folder worked like a charm. Here's the link:
    https://support.gog.com/hc/en-us/articles/213 … etc?product=gog
  • Gothic - SUCCESS
    Joseph_Joestar wrote on 2024-01-22, 11:11:
    The GOG release of Gothic ships with a version of ddraw.dll which may be too new for some retro systems. It makes the game very sluggish.
    Deleting that file from the Gothic\system folder should resolve the issue.
  • Gothic 2 SUCCESS
    You need to remove all the wrappers like draw.dll in the game folder, or else the game won't work on Windows 98SE
  • Hitman: Agent 47 SUCCESS / FIX FOR 3DFX CARDS
    Same issue on real 3dfx hardware in Glide mode as DeusEx GOTY, same solution. Except an additional step: start the Setup.exe program from the game's folder and set the renderer to Glide manually.
  • Hitman 2: Silent Assassin SUCCESS
    On my Voodoo3 rig demands d3dinput.dll, the Config.exe does not allow to set the renderer to Glide, but allows to disable Hardware T&L. May be playable with DirectX 8 installed in D3D mode.
  • Icewind Dale SUCCESS
  • Icewind Dale 2 SUCCESS
  • Legacy of Kain - Soul Reaver SUCCESS
  • Legacy of Kain - Soul Reaver 2 SUCCESS
  • Legacy of Kain - Defiance SUCCESS
    Requires DirectX 9
  • Medal of Honor Allied Assault Battlechest SUCCESS
  • Mortal Kombat 4 - PARTIAL SUCCESS
    GOG has used _inmm to patch the game to play the CD audio soundtrack with libvorbis, and the version of libvorbis is not compatible with Win98. I used my own _inmm to re-patch and re-configure it, and the game works just fine. Removing nglide files still applies. It is a partial success because I couldn't get 3dfx Glide mode to work with Voodoo3 3000, but Direct3D mode works just fine.
  • Neverwinter Nights Diamond FAILURE SUCCESS
    Making NWN Diamond work on 98SE is a bit involved. The .bin file is larger than 2Gb, and while FAT32 supports files up to 4Gb, W […]
    Making NWN Diamond work on 98SE is a bit involved. The .bin file is larger than 2Gb, and while FAT32 supports files up to 4Gb, Windows 98SE doesn't, even with the unofficial fix. The size of the file shows as negative in Explorer, and the installer freezes the whole system.
    You can either install it on a Windows XP PC and copy the files (the easy way), and it should work.
    The way I did it, I installed innoextract via homebrew on MacOS and typed in innoextract setup_nwn_diamond_2.1.0.21.exe --gog. It extracted the EXE file but demanded unar to be installed to be able to extract the .bin file. So I installed unar, again through homebrew, and ran the command once again.
    The process will create a few folders, what you want to do is to copy the contents of \Support\Game\ folder into the \Game\ folder, where the main game files are. After that, just copy the contents of the \Game\ folder to your Windows 98 PC and it will just work.
  • Quake II Original SUCCESS
  • Return to Castle Wolfenstein SUCCESS
  • Rune Classic SUCCESS / FIX FOR 3DFX CARDS
    Do not use the offline backup installer - it won't work. Download Rune Gold (original version) from the Goodies section instead. […]
    With 3dfx Voodoo3 3000, need to use the same method as with Deus Ex - remove the following files from the game install folder:
    glide.dll
    glide2x.dll
    glide3x.dll
  • Sacrifice SUCCESS
    Will ask for a CD Key.
  • Serious Sam The First Encounter SUCCESS
  • Serious Sam The Second Encounter SUCCESS
  • Sid Meier's Alpha Centauri SUCCESS
  • SiN Gold FAILURE
  • StarTrek Voyager - Elite Force SUCCESS
    I have not figured out how to enable 3dfx OpenGL on my Voodoo system, but it works perfectly well on that computer. The option exists on my Windows XP system that has no Voodoo graphics. To restore A3D functionality for Aureal Vortex cards I had to copy the following files from a Soldier of Fortune Platinum installation to the StarTrek folder:
    a3dapi.dll
    a3dsnd.dll
  • Star Wars Jedi Knight: Dark Forces IISUCCESS
  • Star Wars: Knights of the Old Republic SUCCESS
  • Star Wars: Knights of the Old Republic II - The Sith Lords SUCCESS
  • Stronghold HD SUCCESS
  • Temple of Elemental Evil SUCCESS
  • The Elder Scrolls III Morrowind SUCCESS
  • Thief Gold FAILURE
  • Thief 2 FAILURE
  • Ultima IX Ascension - SUCCESS / FIX FOR 3DFX CARDS
    Deleting glide2x.dll from the game's installation folder makes it playable, tested on P3/Voodoo3.
  • Unreal Tournament GOTY SUCCESS / FIX FOR 3DFX CARDS
    On 3dfx Voodoo3 3000, the game runs in D3D mode out of the box. Running it in Glide mode causes it to run in a window/software mode. To fix this, follow the same steps as with DeusEx to remove nGlide files from Unreal Tournament install directory\System\
  • Unreal Gold SUCCESS / FIX FOR 3DFX CARDS
    On 3dfx Voodoo3 3000, the game runs in D3D mode out of the box. Running it in Glide mode causes it to run in a window/software mode. To fix this, follow the same steps as with DeusEx to remove nGlide files from Unreal install directory\System\
  • Vampire the Masquerade Redemption SUCCESS
  • Warlords Battlecry 3 SUCCESS
    For some reason the GOG version of Warlords Battlecry 3 requires DirectX 9 libraries.
  • Worms Armageddon SUCCESS
Pentium 2 300MHz/Matrox Mystique/Sound Blaster AWE 32 Value
Pentium 3 733MHz/3dfx Voodoo 3 3000/Aureal Vortex 2 (Diamond Monster Sound)
Pentium 4 2.0GHz/GeForce4 Ti4200/Sound Blaster Live!
Core2Duo Q9400/GeForce 8800GT/Creative X-Fi Titanium Fatal1ty
Reply 1 of 20, by songoffall
  • Arcanum FAILURE
  • Deus Ex SUCCESS
  • Legacy of Kain Defiance SUCCESS
    Requires DirectX 9
  • Legacy of Kain Soul Reaver 2 SUCCESS
  • Sacrifice SUCCESS
  • Thief 2 FAILURE
  • Unreal Tournament Gold SUCCESS
Reply 2 of 20, by Joseph_Joestar
Just a side note, that so called "unofficial service pack" is known to break things in various ways.
You're better off dual-booting Win98 and WinXP. Most GOG games will install fine under WinXP and can be copied over to Win98 as needed.
My retro stuff
Reply 3 of 20, by songoffall
Joseph_Joestar wrote on 2024-01-17, 08:05:
The "unofficial service pack" is its own can of worms, it took me two days to figure it out. For example, both me and Michael MJD on YouTube were unable to install it the normal way, especially the core components, but I was eventually able to find a workaround - Michael was killing INFEX, which was not responding, but that would end the installation prematurely and leave a broken installation. WINOLDAP is what needs to be killed, which allows the installation to go forward and finish. I needed the SP to fix the memory caching issues with Win98SE, which has better ways of doing, like modern XMS managers, but at the time I thought this would be faster. Oh how wrong I was.
One thing the "unofficial service pack" fixed was the performance issues I was having after a clean install even with all drivers - a weird thing that kept happening and I don't know the reason, installing anything would make the mouse lag and stutter and the whole system would almost lock up until the install was done. Overall, there was one UPNP DLL broken on startup, which I just removed from startup and so far the system is remarkably stable and the results I'm getting now are consistent with pre-SP Win98 installations.
Reply 4 of 20, by Joseph_Joestar
songoffall wrote on 2024-01-17, 08:29:
Sounds like DMA wasn't enabled for the hard drive and/or CD-ROM in Device Manager. Either that, or some driver mismatch.
I suggest searching the Vogons forum for "unofficial service pack". You'll find a bunch of posts where people had inexplicable issues on their Win98 system with that installed, which immediately went away after they stopped using it.
But if your system is stable, then more power to you. I'm just advising to be cautious when installing that stuff on a retro rig which is primarily aimed at gaming.
My retro stuff
Reply 5 of 20, by songoffall
Joseph_Joestar wrote on 2024-01-17, 08:50:
Sounds like DMA wasn't enabled for the hard drive and/or CD-ROM in Device Manager. Either that, or some driver mismatch. […]
And your advise is more than welcome. As I already said, the whole service pack is shaky and mostly unusable unless you do certain things at certain points.
Btw, the service pack does enable DMA for all devices, it's a separate option. I can only assume that the VIA drivers did this when installing them, and the nForce drivers did not.
There was something else that bothered me. One of my drives reported a bunch of bad clusters before the update, absent on a previous Windows install (VIA chipset) and after the update they miraculously disappeared. Scanning with Seatools showed me a single bad cluster, but I already knew about that one.
Reply 6 of 20, by songoffall
  • Mortal Kombat 4 - FAILURE
    Might be fixable. The problem is with libvorbis.dll, maybe it will launch with a replacement. The game also contains nglide wrapper, which too might need to be removed.
  • Ultima IX Ascension - FAILURE
    nglide causes gray screen after the intro cinematic. Might work after removing nglide properly.
  • Gothic - SUCCESS
Reply 7 of 20, by Joseph_Joestar
songoffall wrote on 2024-01-22, 10:43:
Gothic - SUCCESS
My retro stuff
Reply 8 of 20, by songoffall
Gothic - SUCCESS
It was fine on my system, but then, my system is overkill for Gothic. Thanks for your input, mate!
Reply 9 of 20, by songoffall
  • SiN Gold FAILURE
Reply 10 of 20, by songoffall
Reply 11 of 20, by songoffall
Another update: the "Unofficial SP" does introduce a lot of weird stuff, so I eventually ended up ditching it. I actually ditched the Windows 98SE CD I was using too, it seems to have degraded over the years and the installation program failed to notice file corruption. Fresh Windows 98 SE, with the usual updates and a few options from 98SE auto patcher - there's a lot in the auto patcher that makes the system unstable as hell, third party and unofficial modules are to be avoided. But two fixes in particular seem to be good - one of them deals with large HDDs, and the other - with files larger than 2Gb, which makes me think NVN Diamond could be installed.
Reply 12 of 20, by songoffall
  • Gothic 2 SUCCESS
    Both Commandos and its expansion freeze your system on hardware level if you have K-Lite Codec Pack installed. Black screen, audio plays, nothing else works.
Reply 13 of 20, by songoffall
Update: now that I have a real 3dfx Voodoo3 3000 card, can test these games on a wider variety of hardware. Added a fix for DeusEX GOTY (normally it just freezes with Glide on Voodoo3).
Reply 14 of 20, by songoffall
Just an update, got the following games to work on a P3/Voodoo3 rig:
Anachronox
DeusEx
Hitman Agent 47
Rune Gold
The details have been added into the post.
Reply 15 of 20, by songoffall
Another update; MK4 fix added to the original post. Will update it once again once I've been able to get the glide mode going.
Reply 16 of 20, by Joseph_Joestar
songoffall wrote on 2025-11-24, 06:06:
The MK4 Glide issue isn't specific to the GOG version.
I have the retail CD release, and its Glide mode doesn't work on a Voodoo 3, while working perfectly fine on a Voodoo 1. At a guess, MK4 might be one of those statically linked Glide games or something.
My retro stuff
Reply 18 of 20, by songoffall
Joseph_Joestar wrote on 2025-11-24, 07:32:
Thanks for your input, friend. I have never owned a Voodoo1 and my first proper GPU was a GeForce2 MX200, which is what I originally played MK4 on, so the only way to know is when someone tells you 😀)
Reply 19 of 20, by songoffall
DEAT wrote on 2025-11-24, 22:05:
I documented a good majority of the Win9x library back in 2021-2022:
https://docs.google.com/spreadsheets/d/1TrTaM … 0RrrZ-4HvcBSfM/
I doubt that most of those have changed since then.
It's quite a comprehensive list, friend.
Still, I think it is useful to the community, having a topic like this where I document how to get each and every one of these games working.
Also, I saw you wrote Anachronox wasn't compatible with Windows98 and I have it working on multiple Win98SE systems right now. Getting it to have proper performance on Voodoo3 3000 was a bit involved but doable.
I have also listed a way of running Giants: Citizen Kabuto on Win98SE, with files provided by GOG support.
I have also confirmed Vampire the Masquerade Redemption to work on Win 98SE.
