ISA Modems / DOS & Windows 3.x
First post, by Scythifuge
Greetings!
I am installing 56k modems in all of my retro PCs. PCI winmodems for the P3's and maybe my AthlonXP, and an ISA modem in my 486. Since I have a Diamond branded OPTi sound card (with an OPTi wavetable daughterboard) and soon to have a temporary Diamond Trio64 (the Vision864-based Stealth 64 card was DOA, unfortunately - trying to find a replacement) VGA card, I want a Diamond 56k ISA modem, just because (maybe I'll call this build, The Diamond Box.) I have an old Gateway ISA modem in the interim.
My question is, will all ISA modems work in DOS and Windows 3.x, since they are hardware modems? Almost every Diamond ISA card I see comes with no software, and the internet is getting terrible as of late with all sorts of things we used to easily find now not showing up in searches. I did manage to connect to a BBS still in operation with an external serial modem on my 486 (and it was AWESOME and nostalgic, to say the least,) but I have a spare ISA slot, and would like to clear up some shelf space on my retro PC desk.
Thanks!
Scythifuge
Reply 1 of 23, by kingcake
AFAIK soft- or win-modems were always PCI or AMR. I never saw an ISA one as a system builder, anyway. I stand to be corrected.
Edit: Forgot about MWAVE cards!
Reply 2 of 23, by wierd_w
There *were* very early IBM HSC modems that were ISA. They used the isa plug and play bios extensions to get configured, and were basically just a crappy soundcard.
See for instance, here, with this 'it's obviously lucent' and being 8bit isa.
Note the complete lack of config jumpers.
https://www.ebay.com/itm/196110573144?hash=it … egAAOSwsHpk7hkl
A proper vintage modem reports itself as a serial port, and has config jumpers for IRQ and base address. All the HSC winmodem trash lacks such hardware.
Being ISA is not a guarantee of being 'a real hardware modem'
Reply 3 of 23, by Scythifuge
wierd_w wrote on 2024-01-18, 04:32:
There *were* very early IBM HSC modems that were ISA. They used the isa plug and play bios extensions to get configured, and we […]
I was afraid of that...
Well, if I can't find a 56k Dos/Win 3.x friendly ISA modem, I can always use this U.S. Robotics external modem and just have to deal with it. I'll keep looking, though.
Reply 4 of 23, by wierd_w
The vast majority of ISA modems will be hardware UART (actual serial ports) based, and not crap winmodem HSC garbage.
The IBM ones stand out prominently in my memory, as the mom&pop I worked for BITD got a shipment of them in 'real cheap', and they staunchly refused to work 'reliably' in anything but pentium mmx systems of 133mhz or faster.
Putting one in a 486 was a paIn I would not wish upon anyone.
Quality vintage hardware will have jumpers, and wont have that plastic shroud on it. Those will work with anything, as they report themselves as just dumb serial ports.
Reply 5 of 23, by chinny22
As long as the PC supports "fast" 16550 UART I would have thought external is more desirable? flashy lights are sexy 😀
Out of interest what are you using the modems for? just the BBS's or some project?
Reply 6 of 23, by kingcake
Of course! I totally forgot about the infamous MWAVE cards.
Reply 7 of 23, by wierd_w
kingcake wrote on 2024-01-18, 05:48:
The *really infamous* ones, imo, were the early PCI Genica cards. Came in a generic chinesium paper box, and failed 3/4 of the time in spectacular ways that were inconsistent, and obscure.
We started calling them "Junkica" modems at same said mom&pop.
The IBM HSC crap, at least, DID work 'acceptably' in highend (for the time) pentium systems. (Even if they did make the system lurch to a crawl the instant dialling happened...)
The Genica PCI ones just did squirrely shit in everything.
I was very careful back then, to always insist on USR or Rockwell chipset modems, with hardware UARTs. Customers, however, could not fathom paying 20$ more for a 'real' modem.
Reply 8 of 23, by jmarsh
wierd_w wrote on 2024-01-18, 06:51:
They needed the processing power because the "modem" was just an ADC and the signal processing/decoding had to be done in software. They tended to work better if you limited the maximum connection speed with AT commands before connecting, but then of course you weren't using all the possible bandwidth.
Reply 9 of 23, by wierd_w
Yup. 'Really just a crappy soundcard' is accurate.
The point being made was that the 'only' downside to using one of them in your high end rig, was that all the oomph of your high end rig was blown 'just staying connected'.
As opposed to the Genica pci ones, that caused mystery lockups, bluescreens, only 'certain' programs to force-close, with 'now DIFFERENT programs lock up!' Happening when you changed it out... etc.. with no apparent rhyme or reason for any specific cluster of symptoms, other than "is Junkica installed? : YES"
Reply 10 of 23, by Scythifuge
chinny22 wrote on 2024-01-18, 05:44:
I do want to visit some BBSs and have considered starting my own. I think that it would be cool to do so! I remember chatting with multiple people on a bbs back before we had the internet and social media. I think it would be a nostalgic and cool alternative to today's internet. I used to talk with people via mIRC and I read that many people still communicate that way. I also want to play around with old school multiplayer games. I used to play Doom, Wing Commander Armada, and some other games via modem. Later on, I bought a serial cable and a null modem adapter and friends would bring their PCs to my house and we would play Warcraft, Blood, and Duke Nukem. Many people in my area have cable phone. I used our cable phone line to call a bbs, so now I want to experiment with old school dial-up gaming, hehehe. I also want a modem in my 486 which works in DOS and Windows 3.x, for "completeness," especially if I can find a Diamond Multimedia ISA modem which works under those environments.
Because of my motorcycle accident a few years ago, I have a lot of time on my hands and often tinker with my retro machines to reminisce and to pass the time. It is why I make so many posts on Vogons, asking questions and what not, and do all of these anachronistic projects (such as my plan to make midi game and "professional" music with these old systems. I also plan to write, using old word processors on the 486 and on one of the Pentium 3s. My office/library is like a museum and 80s-90s sanctum, save for my modern TV which I use as a monitor with my modern main system. I have a lot of little projects in the pipeline, such as creating a local line just for the retro machines with an ftp server to more easily transfer files.
Reply 11 of 23, by Scythifuge
This old Gateway 2000 modem has "1994" printed on the pcb, and a sticker from 1/25/95, and it has jumpers instead of dipswitches. It should work, but definitely not a 56k. I'll research it later on and try to post a pic of it. It is probably a 28.8k modem.
Reply 12 of 23, by Cyberdyne
Holy grail of ISA modems is U.S.Robotics.
Reply 13 of 23, by Scythifuge
Cyberdyne wrote on 2024-01-18, 13:36:
I came across a pdf manual of some form of 56k U.S. Robotics modem, and it mentions Windows 3.x support, so I think I need to hunt down that particular modem and give up on the Diamond brand name, hehe. If it works under Win 3.x which runs on top of DOS, I am hoping it will work in DOS, as well.
Reply 14 of 23, by kingcake
jmarsh wrote on 2024-01-18, 09:16:
The sound and modem section shared a codec. If you used sound at the same time the modem was limited to 14.4 due to bandwidth limitations. AMR modems worked in a similar fashion, they basically used an AC97 codec with the CPU doing the rest of the work.
Reply 15 of 23, by Scythifuge
kingcake wrote on 2024-01-18, 18:00:
That makes sense. I have seen many soundcard-modem hybrids, but unlike many other components, I never felt the urge to buy one to experiment with. Certain hybrid cards seem weird to me, with the exception of cards with both ide and floppy controllers (I had to buy one once, because my floppy controller on my Pentium 90 stopped working.) It just seems to make sense to me to have most cards do their own things on their own slots. My Pentium 3 700 has an AGP Voodoo5, a Sound Blaster Live!, a win modem, a NIC, and still has two empty PCI slots (I am considering throwing my Voodoo2 in there since it is otherwise not being used.)
Reply 16 of 23, by kingcake
Scythifuge wrote on 2024-01-18, 18:22:
There are some ISA Sound/Modem combos that I would consider decent. Aztech made some for Packard Bell that had Rockwell chipset hardware modems on the same card as a Crystal sound chipset + real Yamaha OPL3 chip.
Reply 17 of 23, by Scythifuge
kingcake wrote on 2024-01-18, 23:28:
I just recently acquired an OPTi sound card with a crystal chip and a Yamaha OPL3 because it is similar to the very first soundcard I ever had, back when I got my 486SX/33 with a Reveal Multimedia Upgrade kit. It is one of the Diamond branded cards in the 486 I put together and am seeking a modem for, hehehe..
Reply 19 of 23, by wierd_w
Yes. That looks like a good hardware modem.
V.90 bis AND x2
There were 3 standards for 56k modem, and v.90 was the best one. KFlex was the 3rd one, and was rather maligned.
But if you really want a diamond multimedia card... this is also a jumpered modem...
https://www.ebay.com/itm/254461904732?hash=it … ABk9SR6iGzpykYw
Warning that it is connexant chipset though! It could be a winmodem in disguise.
The USR modem is almost certainly better.
