WolfenStein 3D help
First post, by HellMarine
Um hey i got everything for WOLF3D and i got it installed finally but after installation nothing happens.I typed in some stuff to see if it would do anything but it aint.Im a newb so help me please.
Reply 1 of 2, by eL_PuSHeR
Hi, Welcome to the forums!
Please read the POSTING GUIDELINES.
*** Moving to DOS in the interim ***
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 2, by Mike
Ok, here is what you do... What you do is install Dosbox... http://dosbox.sourceforge.net/news.php?show_news=1
If Dosbox is slow, then you press Ctrl and F12 and the cycles should increase.
If you still have problems, then I will suggest that you install VirtualPC from Microsoft, but, beaware that it can be quite difficult to configure, it depends on what you know about PCs...
If VirtualPC was a failure or you have some other problem, then I will suggest buying a Pentium 100 on Ebay, but, I don't think you would have to go that far! 😀
Anyway, if you have any more concerns, then post a reply.
Mike
