First post, by Unregistered
I would like to play with Duke Nukem 3D with sound but it doesn't work! I tryied Anything!
Sound Card Type: SB 128 PCI
Windows uses IRQ 16
I tryied to use IRQ 5 & 7 in Duke nukem... not working...
I really don't know what to do...
Please help!
P.S: On Windows Emulation I only hear some noise like: Tick-tick-tick. I think it was the same thing on VDMSound Emu using IRQ 5 or 7...
Reply 1 of 2, by Nicht Sehr Gut
"Vague Post of the Day" goes to... "Unregistered"
You've told us almost nothing about your problem. You should follow the Posting Guidelines that are at the top of every forum.
What OS are you using? is probably the most critical question. You could probably save some discussion by doing a "Quick Search" (at the top of the page) for Duke Nukem and read some of the numerous posts about what to do with it.
Reply 2 of 2, by Snover
eheh.. I'd nominate it for second-worst description of all time. Nicht, damn, where's your witty scripted response when I need it?
In any case, I'm closing this thread: INCOHERENT. If 'Unregistered' wishes to get a response to this problem, please follow the posting guidelines.
Yes, it’s my fault.
