First post, by jnemo2004
Hello Sirs,
I bought the motherboard FIC PT-2000 with a strong corrosion and very dirt.
After cleaning the motherboad looks good.
I connect it and the diagnostic card stops in C1.
I revised again the motherboard and I found a diode with a "leg" broken by the corrosion.
I am not able to identify this diode. Could you please help?
Thank you very much
