First post, by demiurge
So there is no information on this but I have this wonderful new AT board and it has some weird "Green PC connector" with what seems like an enable switch on JP15 but a second set of pins for JP5.
On other boards of the time, the "Green PC connector" seems to be a sleep SMI (system management interrupt) as seen on the ATC-1000+. a pull up 8.2Kohm to 3.3V for the enable pins is found on the NA121 What does "sleep" even do in DOS?
Supposedly there are some "control pins" my model seems to have three pins (<=4) and a similar model has 8 pins or 4 signal and 4 ground. Anyone know what these could be for? The manual that even documents them (8-pin version) only provides the attached information.
    8.12 KiB
    12.36 KiB
Reply 3 of 8, by demiurge
giantclam wrote on 2024-01-29, 00:53:
Shuts down video, hdrive, and on some shuts down cpu fan as well.... it's basically just a power save mode
I think you are right. Do you think it uses a momentary or latching switch?
Reply 4 of 8, by giantclam
rasz_pl wrote on 2024-01-29, 02:08:
Afaik early Suspend to Ram implementation
Yeah... iirc using the APM interface, before ACPI and 'S' modes came into being circa '96
demiurge wrote on 2024-01-29, 02:51:
It really depends on how it's implemented ~ most were momentary on/off but I have seen it with latching switches.
Reply 5 of 8, by Horun
Not worth messing with from my experience.....
Reply 6 of 8, by demiurge
Horun wrote on 2024-01-29, 03:52:
It may not do anything useful, but I want to wire up the option.
giantclam wrote on 2024-01-29, 03:19:
I got a spare momentary button I will see how it works tomorrow.
Reply 7 of 8, by demiurge
I couldn't get the switch to do anything. Maybe it has to have powermanagement enabled in the BIOS?
Reply 8 of 8, by demiurge
demiurge wrote on 2024-02-24, 03:16:
Got the Green PC button to blank the screen (with three beeps) with a momentary button after BIOS settings.
