First post, by clb
Hey all,
I've recently got into Windows 3.1 time-wasters again.. Tetris, Mine Sweeper, FreeCell, Chess, TetraVex, all that stuff.
While playing some of the old Windows classics, I'd like to listen to some great MIDI tracks.
But I am struggling to find a good MIDI player for Windows 3.1 🙁
What I'd like to have is simply:
1. be able to add a subdirectory, e.g. C:\MIDI\ into a playlist.
2. be able to do shuffle play of all said MIDIs.
3. be able to handle a large selection of MIDI files.
Here is what I have tried so far:
The attachment Windows_MediaPlayer.png is no longer available
but you have to one-off load every file, so not suitable.
Then there's the Creative MIDI player that comes with Creative's Sound Blaster AWE64 Gold driver disk:
The attachment Creative_MIDI_player.png is no longer available
that one is quite nice and clean as far as UIs go, but it has a limitation of only being able to add 100 files to playlist, and there is no shuffle option (that I could find), so didn't quite cut it.
Then I found MIDI MADE MUSIC Jukebox:
The attachment MIDI_MADE_MUSIC_Jukebox.png is no longer available
The UI is a bit all over the place, but that's not a problem if it would work. This player seems to have two separate playlist areas, one for the top side of the screen that mimics a physical Jukebox, and then at the bottom side for a playlist. There are also size limits to number of files, and for some reason it looks like shuffle play works only for files that are added by hand one by one (?) to the physical jukebox grids.
Then I also found this MediaSauce thing:
The attachment MediaSauce_1.1_demo.png is no longer available
but only a demo version, and could not find a shuffle button even if I did source the real version.
Then I found this Midiplus v2.15 thing, although it only blanks the screen briefly and does nothing. The thing gives me a MS-DOS icon as if it was a DOS executable, but when I run it from DOS, it says "This program cannot be run in DOS mode". Maybe that is a Win95 program I suppose. (although somewhere on Archive.org I think I saw a text "Midi Plus 2.15 is the last version that works on Windows 3.1, 2.17 requires Windows 95")
The attachment MidiPlusv2.15.png is no longer available
So... any recommendations on a good MIDI player that would be able to load a large playlist of files and shuffle play them?
Or if such a MIDI player doesn't exist, then perhaps recommend a Windows 3.1 MOD player?
Thanks!
Reply 1 of 4, by theelf
Wingroove
Funny you tested everything exept the only good oneand most famous!!!
Reply 2 of 4, by buttertweet
Also Creative does have shuffle play. On the main player, click on the silly graphic that looks like a 3.5 drive with a blue diskette in it. One of the weird looking arrow icons will enable shuffle. But the 100 song limit remains.
Reply 4 of 4, by wierd_w
Iirc, there was a win32s version of winamp?
Oldversion.com has old versions of winamp. You can try them with the win32s patch installed.
http://www.oldversion.com/windows/winamp/
