First post, by Burinis
I have a virtual machine in VirtualBox 6.0.24 with Windows XP SP3 and a VBoxVGA video adapter. 3D acceleration works great in it. But I decided to make two more Windows XP SP3 virtual machines, but with VBoxSVGA and VMSVGA video adapters. But when installing Guest Additions (even if you do not install Direct3D), the following error occurs with a VMSVGA video adapter:
They say on the Internet that the VMSVGA video adapter has high performance.
In the case of the VBoxSVGA video adapter, no errors occur and everything works fine, but 3D acceleration does not work.
On all virtual machines, 3D acceleration is enabled in the display settings.
Running old games on a real computer and buying an old computer is not an option. I removed VMWare Player so that it would not take up extra space on the computer.
Are there any other ways to use 3D acceleration? What drivers are needed?
