First post, by PCIe_awe64_gold
Today I felt like messing with a 386 again so I pulled out some kind of DTK pre-built 386 motherboard. Plugged in the matching VGA card and the I/O controller thing as well as the original 125 MB hard drive. The drive is known working and everything is installed on there.
The CMOS battery has been gone for 20 years so the factory settings are gone. The BIOS is very much not plug and play so you have to manually set the HDD specifications. But the drive setup is nothing like anything I've used before, you cannot manually type the specifications in, rather you have to select a between 49 different predefined types. None of which are a match for the capacity, cylinder count, etc. for the disk I have. I'm 99% sure the drive is what it came with from the factory so what gives? At boot it just gives me a fixed disk controller failure. Boots fine from floppy but I really don't want to be stuck with floppies.
If it means anything, the BIOS vendor is Datatech and apparently the version is 3.0
I'm really not familiar with pre-Pentium PCs so sorry for my ignorance.
