Win98SE copying files...
First post, by 8bitfink
I have an issue with installing Win98SE, it gets to Windows is copying files please wait..
Then it just stays there nothing?
I have FDISK
Deleted Partitions
Created a new Primary Partition
Formated C:
I set parameters in BIOS CDROM,C,A
Disabled Virus Checker
Removed all hardware except GFX card
Have PS2 Kb and mouse connected
Running PII-300MX
64k RAM [have more though took the others out in case]
Any ideas is driving me nuts, never had an issue like this before.
Reply 1 of 6, by PD2JK
64k of RAM, you need 640. 😉
Of course you mean 64 MB.
Do a memory test, memtest86+ for example.
Does the floppy work? Or you could disable it in the BIOS. Maybe the setup looks for its existence.
has all kinds of stuff
Reply 2 of 6, by 8bitfink
🤣 sorry typo, I just thought of that when I went inside what I posted ; My mind thinks to much.
Have not tested MEM though had Windows 2000 on it previous and worked fine.
Floppy does work as I ran FDisk with it on Win98 Startup Disk and Formatted.
I will see what happens when I disable it - thanks.
Reply 3 of 6, by 8bitfink
Nope same thing.
Reply 4 of 6, by rain
After formatting c: drive use boot floppy disk to use " START WITH CDROM SUPPORT "
After type d: to enter cd drive and type setup
Reply 5 of 6, by 8bitfink
Yes I had tried that also, I might rip another disc incase it is the cd itself.
Reply 6 of 6, by 8bitfink
All good, delted into 1999 and grabbed a copy of 98SE. Worked fine, must have been a flatlined copy I had.
