First post, by Marco
Hi all,
again a mysterious issue: my ide2cf adapter works flawless when connected directly on/to the ISA hdd controller. But when I connect it via cable, the system won’t boot. It doesn’t matter which connector, direction etc. The cable works flawless with my two hdds.
PS: for connecting the adapter to the cable I just use a standard 40pin male to male bridge.
Looking forward to ideas 😀
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@63 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | WDC160GB/7200/8MB | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
Reply 1 of 14, by weedeewee
Have you verified that pin 1 on the adapter is connected to pin 1 on the cable when connected through the 40 pin male to male bridge ?
Do not ask Why !
Reply 2 of 14, by Marco
At least I tried the adapter in each possible position and direction „into“ the cable. Is it that what you mean?
Reply 3 of 14, by weedeewee
No. I mean what I said.
To clarify it a little,
just take an IDE cable and put the connectors together,
any way you like using your male to male connector,
so that pin 1 on one connector (it's marked by a little arrow on the connector and tends to be the colored wire on the flatcable),
is connected to pin 1 on the other connector, and all the pins are connected, ie 1 to 1, 2 to 2, etc...
Do not ask Why !
Reply 4 of 14, by konc
weedeewee is right, confirm that pins are mapped correctly at the other end when using the gender-changer. It's hard to explain in writing but I bet they aren't.
Reply 5 of 14, by Marco
Thanks I will check at home. This is my bridge. It’s a simple pin extender. Pin-by-pin
Reply 6 of 14, by weedeewee
I know what you meant with the male bridge. Please, Understand that you will never get the cable connected correctly to the ide2cf adapter with just that bridge.
Do not ask Why !
Reply 7 of 14, by Marco
I think I understand. I need a bridge which somehow re-connects the pins correctly.
Reply 8 of 14, by wierd_w
It will be inverted, no?
Pin 40 would be pin 2, etc..
Besides, those kind of adapters usually dont respect master/slave operation ANYWAY.
There are MUCH BETTER adapters, that ARE made for life on a (shared) cable.
Like this Syba one.
https://www.amazon.com/Syba-Compact-Adapter-E … a5b58feeadc4dc3
Reply 9 of 14, by Marco
Thanks as well.
This is the real adapter I use behind the (wrong) bridge:
https://www.ebay.de/itm/123970756803?mkcid=16 … emis&media=COPY
Reply 10 of 14, by weedeewee
You know, if you have another one of those male to male adapters and an ide cable, you can hook it up. Though you'll need to have it at the end of the chain. not in the middle, if that even cooperates with another device.
ie,
controller, ide cable, male to male, ide cable, male to male, ide2cf adapter.
the first one sticks the odds to the evens, and the second one reverses them again. Only thing left to mind is that pin 1 connects to pin1 and not pin39. and do not use the middle connector on the second cable from the controller.
Do not ask Why !
Reply 11 of 14, by Marco
Ha interesting approach thx all
Reply 12 of 14, by weedeewee
or this https://www.ebay.de/itm/235187226398 IDE 40-poliger Stecker auf Stecker flaches Band Festplatte Verlängerungskabel ?
Do not ask Why !
Reply 13 of 14, by snufkin
Haven't quite worked it out in my head, but could you just get a 40 pin male IDC connector and crimp it on to an existing cable? Or get a whole extension cable like https://www.ebay.co.uk/itm/115877431226 ?
Reply 14 of 14, by Marco
Thank you all. With delivery expenses this will become to expensive. I therefor will replace my flash adapter and send to old one back.
An extension cable won’t do it.
Thanks a lot to all
