I have a system based on a Soyo SY 7VMA-B (Apollo Pro 133Z) with an SB Live SB0100 and I've had no issues with it. I haven't used it for any DOS games (I've never played a DOS game) so I cannot comment on that aspect, but it has worked fine for Half-Life. You might have to swap it from one PCI slot to another after installing the drivers, that sort of thing is pretty typical with Via chipsets of that era.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
