First post, by UpNorth
The hard disk in my PS/2 model 30 has died. These drives use an edge connector to transfer data AND power. What would be the easiest way to power an IDE drive (XT-IDE setup)? It's a physical IDE drive, not a CF card, so I do need that power.
I am looking for a simple way to do this, e.g. find some pins/connector on the motherboard and modify a cable with a MOLEX connector on one end and the necessary connector for the motherboard thingy on the other. Something like that.
