First post, by JohnnyV
Hello all, I got this Siemens-Nixdorf Scenic Pro D6 (PII 266Mhz) from my local Scrap Yard and when I opened it up for cleaning I noticed this part. Never seen it before and have no clue as to it's function. At first I thought it was some kind of sensor to stop the pc from booting with the top cover removed but even without the top cover on the system boots normally into Windows 98 . It connects to nothing else besides into the motherboard with that flat cable. Anyone here has seen it before and has an idea as to what this is ??? Tried to find a manual or more info about it but no luck so far...
    150.25 KiB
    Flat Cable
    90.08 KiB
    Unknown part Bottom side
    98.89 KiB
    Unknown Part Top side
    179.24 KiB
    Case with part in middle case support
    181.26 KiB
    Cable Connection to the Motherboard
Reply 1 of 7, by momaka
Just a wild guess here, but perhaps intrusion detection.
Go in BIOS and see what the logs say. Try clearing them, then see if you get an intrusion detection flag set off when you restart the PC without the cover. Might also have to set BIOS to register (i.e. not ignore) intrusion detection for this, though. But again, this is just a wild guess on my end.
Reply 2 of 7, by Horun
Yeah possible intrusion detect but most do not have that many wires...
Reply 3 of 7, by elszgensa
Look up the system board and see what the description for that connector says. I found this site saying it might be a D983 but the connectors don't match up with yours.
edit: probably a d1085-a or -e. manual says "cover detection".
Reply 4 of 7, by Deunan
These 4 middle traces look like they are meant to be cut, for some sort of configuration maybe? Perhaps this wasn't meant to just touch a solid piece of metal that shorts everything together but rather there could be some piece of electronics connected? Some kind of plastic card with similar contacts? At least as an option, maybe it was never used that way but the design allowed for it. This would provide more than simple intrusion detection, it could be asset tracking, HDD data encryption, etc. Such card would be removed (preferably along with HDD) if the machine is to be scrapped obviously.
Reply 5 of 7, by danijelm
To me this looks like a smart card reader. Many models of Siemens-Nixdorf had a smart card reader, but from these pictures Ican't see the front cover of the computer, so I can't be sure
I speak sarcasm as a 2nd language
Reply 6 of 7, by JohnnyV
Bit more info, I've rechecked and that part does not in any way connect with the top cover . As to a Card reader, although there is a slot in the desktops right front pillar it must have been optional as its empty on the inside. I include a frontal picture. Normally there's a green sliding plate in the front but that was damaged so I removed it.
    91.73 KiB
    Recess in the middle with the unknown part (that part makes no contact with the top cover)
    107.2 KiB
    Empty Smart Card Slot on the inside
    102.73 KiB
    Front (smart card slot in the right pillar)
Reply 7 of 7, by StriderTR
I'm going with intrusion detection as well, based on this Siemens Nixdorf System Board I found on The Retro Web.
https://theretroweb.com/motherboards/s/siemen … ard-d1127-a-b-c
Not the exact same board, but it has a very similar connector in the same general location marked as "Cover Monitoring".
Have you looked to see if your specific board in on The Retro Web? They have quite a few Siemens-Nixdorf boards on there. You may get lucky and it's on there already. If not, you can add it. 😀
https://theretroweb.com/motherboards/?manufac … 24&showImages=0
Retro Blog: https://theclassicgeek.blogspot.com/
Archive: https://archive.org/details/@theclassicgeek/
3D Things: https://www.thingiverse.com/classicgeek/collections
