First post, by patrmich
Hello,
I have an old computer (dated 1988, I guess) SANYO MBC17PLUS1.
Such computer has a hard drive , D5146H NEC, 5.25"/HH, 40 MB, MFM Interface.
When I switch the computer on, the following is displayed on the screen :
Invalid Expansion Memory Size
Insert Setup Disk in Drive A and strike any key to reboot
- So, I strike on a key, and then the screen displays :
ROM BIOS Version 1.04
CPU Clock 8MHz Zero wait
Base Memory Size 640 Byte
Expansion Memory size 384 Bytes
BOOT ERROR
I have got no Setup Disk.
Would you know a way to access the contents of a D5146H NEC hard drive (either on this computer or in another one) ?
I thank you in advance for any reply.
Patrick
