First post, by laios67
Super socket 7 motherboard EPOX EP-58MVP3C-M with MMX 233 Pentium and a 2X agp slot . Had a voodoo3 3000 for some time , but I placed it on Pentium III system . What would be a good choice for a AGP card ? . Before reach the bottleneck point but use the maximum of cpu's potential .Dos - win98 gaming . I have few agp cards a Riva TNT2 M64 32MB , Geforce2 MX400 , a Matrox with dual vga (think G400 or G450) ,and FX5200 , ati 9200 but these I supose are too much for a pentium 1 . Is anything good enough from what I got or to look for something else ?
Pentium III 1ghz Coppermine 750mb SBLive! Voodoo 3 3000 AGP
Compaq Deskpro Pentium III 933 EN 500mb Geforce4MX 440 AGP
Pentium 4 1.8ghz Northwood 500mb Voodoo 3 3500 AGP
Pentium 4 1.7 ghz Northwood 1gb Voodoo3 3000 AGP
Reply 1 of 18, by Nemo1985
For agp compatibility purpose (which is flaky on ss7 chipsets) and dos compatibility go for the geforce2 mx400, it's more than powerful for such cpu, not period correct but it your best bet.
Reply 2 of 18, by Minutemanqvs
…and take an « early » driver if you go this route, ithas better compatibility with older hardware than the latest driver you can get for this card. There are numerous threads about that here, but I don’t remember the version usually suggested.
Searching a Nexgen Nx586 with FPU, PM me if you have one. I have some Athlon MP systems and cookies.
Reply 3 of 18, by kingcake
Nemo1985 wrote on 2024-03-24, 10:57:
Won't drivers for that card really slow down socket 7?
Reply 4 of 18, by darry
With the performance of a 233MHz Pentium MMX, AGP vs PCI won't change anything for a video card and, as others have mentionned, cards significantly newer than that CPU will likely give similar or even worse performance than older cards because the newer cards will have drivers with more CPU overhead, which a Pentium MMX will struggle with.
The Geforce 2MX, used with early drivers is probably as recent as is worth trying. My hunch is that a Voodoo 3 (maybe even a Voodoo 2) or a TNT will probably get you the best possible results with that CPU.
Even a Voodoo 2 at 640x480 is severely bottlenecked by a Pentium MMX. 3Dfx Voodoo 2 Super Socket 7 CPU Scaling @ 640 x 480
Reply 5 of 18, by BitWrangler
Some tests on a faster CPU What is the best graphics card for Super Socket 7? My journey :D
There was another testing thread where a Rage 128 went surprisingly well, making it a good budget friendly option for price/availability. Can't find that one at the moment.
Reply 6 of 18, by Socket3
Riva TNT2 M64. Cheap and common so should be rather easy to find. Another cheap solution, but with lower driver overhead would be an S3 Savage 4 but those are far less common.
Reply 7 of 18, by swaaye
Banshee or any of the Voodoo3 cards (including V3 1000 8MB) would be great too. Of course prices are nuts these days.
The issues with NVidia cards are many have blurry VGA, if they have a fan it probably needs to be replaced, and they don't get you Glide and that is unfortunate for early 3D games.
Reply 8 of 18, by laios67
thanks a lot very usefull information , think I'll look for a TnT2 in case I can't find one I'll proceed with Tnt2 M64
Reply 9 of 18, by Nemo1985
kingcake wrote on 2024-03-24, 12:57:
According to my tests (they were made with ss7 cpus though) the best drivers to use are 5.32 or 8.05. That being said the user will look for a tnt 2 or m64 I personally had compatibility issues with it, either way good luck and have fun...
Reply 10 of 18, by marxveix
SS7 i had good results with Geforce2 MX/MX400 7.76 or TNT/TNT2 M64 with very old driver, 2.08 it was.
30+ MiniGL/OpenGL Win9x files for all Rage3 cards: Re: ATi RagePro OpenGL files
Reply 11 of 18, by swaaye
Hey there's also the NV Vanta (TNT2 M64 like) and the original TNT.
Reply 12 of 18, by Sphere478
It’s not impossible to get a radeon 9800 pro working on such systems, but it’s not common.
Radeon 9250/7500/ good chance of working.
9700 may work, haven’t tried though
A lot of people have had good luck with quadro 2 cards running 7.76 driver. I myself haven’t had much luck though.
Sphere's PCB projects.
Reply 13 of 18, by Minutemanqvs
Sphere478 wrote on 2024-03-25, 04:15:
It’s not impossible to get a radeon 9800 pro working on such systems, but it’s not common. […]
I'm running a Radeon 9200/9250, but you need the Catalyst drivers version 5.5/5.6 maximum otherwise you start having issues with SSE needed. I'm having good luck with these cards.
Reply 14 of 18, by laios67
In what system you have the card ? Dos compatibility ?
Reply 15 of 18, by Minutemanqvs
laios67 wrote on 2024-03-25, 10:22:
I what system you have the card ? Dos compatibility ?
GA-7AX (ALI Aladin V), K6-3 500, Windows 2000.
Reply 16 of 18, by laios67
Vanta is in abundance . 16 mb card is it worth to test ?
Reply 17 of 18, by laios67
so go with Mx400 , ok something I already have easy to check
