First post, by eton975
Hi,
I have been trying to get Wing Commander: Privateer running on a system with FreeDOS 1.3. The game works perfectly if I disable all sound in the setup program, but refuses to launch with any sound card specified either as FM music or digitised sound, giving the error message 'Your Privateer sound configuration is incorrect'. I have tried using both ESS' original drivers for the ES1869 and UNISOUND 0.80/0.81. The BLASTER environment variable is set to 'A220 I5 T4 D1 H5 P330'.
Interestingly, other games like System Shock and Duke Nukem 3D do work with sound when the system is first booted, but after attempting to run WC: Privateer with sound once, those games cannot detect the sound card either until a power cycle or hard reset.
Also interesting is that Quake 1.08 (from Phil's benchmark pack) does not like to run on the Am486DX2-80 (it crashes with a floating point exception) but does run on an Am5x86 -P75 as a drop-in replacement.
I have DOS loaded high with 'DOS=HIGH,UMB' in fdconfig.sys and JEMM386 loaded with the 'RAM' option. Mouse driver is CTMOUSE (loaded high) and CD driver is UDVD2+ SHSUCDX (also loaded high)
System specs:
Octek Hippo 15 motherboard with 256KB L2 cache
Am486DX2-80 NV8T running @ 66 MHz CPU
16MB stick of FPM RAM
Diamond SPEEDSTAR 24 (Tseng ET4000AX core) with rev 5.00 VBIOS video card
3com 3c509-TPO NIC
Generic ESS AudioDrive ES1869FC based sound card/Creative AWE64 Value
Transcend 8GB CF card in Startech CF-IDE adapter as Primary master
LG IDE DVD drive as Primary slave
3.5 inch Panasonic 1.44MB floppy drive
Seasonic G-360 PSU with ATX-AT adapter
I have tried this with both an ES1869-based sound card and a genuine Creative Labs Sound Blaster AWE64 Value card, which gives the same error message.
Picture of the system is attached below. Thanks to anyone who can help.
Reply 1 of 4, by eton975
Issue turned out to be a defective ESS sound card and possibly not set high DMA channel (5) after more testing.
Reply 2 of 4, by eton975
Having the same issue with another ESS 1869 based card (pictured), this time under FreeDOS 1.4. Again, other games work but not Privateer (error message also pictured). Yes, I have tried both UNISOUND and ESS' own drivers, as well as changing settings in Privateer's sound setup utility and the result is some games work, some games don't. I have played around with the DMA channels and IRQ settings and still no dice.
Yes, Privateer does launch correctly if I disable all sound support in its sound setup utility.
A different card with the Analog Devices AD1812 chipset works correctly.
Am I stuck or does anyone else have some ideas?
Reply 3 of 4, by eton975
I have retested the AWE64 Value and it works, as long as I pass the T6 value to set BLASTER=
The troublesome new ES1869 card seems to work on my K6-2 400/430TX Win98SE machine under MS-DOS mode. So maybe there is a chipset or OS compatibility issue, as the card's seller suspects.
Reply 4 of 4, by Never_Again
eton975 wrote on 2024-03-27, 04:36:
This BLASTER string is malformed. For the proper syntax see Sound Blaster Configuration Guide.
All ESS cards are SP Pro2-compatible; typically you would use
SET BLASTER=A220 I5 D1 T4
with them. H5 declares the high DMA channel which SB Pro2s do not have; likewise, P330 (the MPU address) is valid only for SB16s and later. Note that the DSP version (Tx) always comes last, the order of the arguments is important.
Generally, SB Pro2-compatible (and earlier) chipsets do not need any drivers for DOS games. The games use their own drivers or third-party ones like AIL, Miles, HMI etc. Some chipsets (like Yamaha YMFs and PnP SB16s) may require initialization software to be run to make the cards functional in DOS; those initialization programs are not drivers proper as they typically do not stay resident in memory after setting up the hardware. AWEUTIL for AWE32/AWE64 does function as a TSR when run in GM or MT32 emulation mode, though.
Some games use the BLASTER var to determine the sound settings and may produce no sound if the format of the var is not what they expect; others have their own detection routines and may ignore the BLASTER var altogether.
Am486 vs. Am586 - see the difference here? Quake is a Pentium game. Even if you managed to run it on that DX2 it would be a slideshow.
