First post, by psaez
Hi
I need recomendations, because I can't find a post similar to this one but for Windows 98: Windows 95 setup guide for the 2020's
I need to know some advices to make the more stable, compatible and funny build possible of Windows 98SE. I'll use it to pass benchmarks, test old games, etc.. For example, I need to know things like this:
- Best Windows 98SE build to install
- Essential software to install
- Recommendations or customizations on install to make a custom more stable install (on that post they remove IE)
- Essential drivers to install
I will use this:
- Tualatin 1400S
- DFI CA64-TC
- 512 RAM
- SD to IDE adapter (or sata to IDE adapter)
- Gforce 3 Ti 200 (or voodoo 3 3000)
I read in some post that some guys recommend this:
- MS Windows Security Update CD February 2004 (https://www.vogonsdrivers.com/getfile.php?fil … &menustate=50,0)
- NUSB 3.6
- DirectX 7.0a? (why not 9?)
Thank you
PD: I have a problem, after installing VIA 4in1 Chipset Driver downloaded from https://theretroweb.com/motherboards/s/dfi-ca64-tc#driver it request a reboot. After restarting, it detects USB port and tries to install drivers, then, it crashes and windows 95 install gets corrupted, damaging SHELL32.DLL and preventing windows to start, simply showing the error that the file is corrupted and that windows can't start and must be reinstalled.
Any ideas about how to solve this?
