DOXBox for Mac
First post, by FilmmakerJWA
How do i mount the harddrive folders in a Macintosh? I'm familiar with Dos quite well, but new to Macs... what exaclty do I type to get a Mac folder mounted?
Thanks!
Reply 1 of 5, by neowolf
The syntax is a little different. Instead of C:\blah\blah it'll be /blah/blah for something on your boot drive. For example say something's on your desktop you wanna mount, it'd be: /Users/yourusername/Desktop/game or for an example from my setup, /Users/neowolf/Documents/DOSBox/c
Also keep in mind that this is (probably) case sensitive. Meaning you need to type the folder name exactly as it is caps and all.
Reply 3 of 5, by neowolf
So it isn't, that makes life simpler! 🤣
I'd assumed it was since most *nix ports tend to be.
Reply 4 of 5, by `Moe`
FYI" OSX supports two different filesystems, one is case-sensitive (UFS), the other one is not (HFS+). HFS+ is usually used by default.
Reply 5 of 5, by neowolf
Actually OS X goes a bit further with Tiger. There's a case sensitive version of HFS+ that's an option now too. However using that or UFS, the other case sensitive file system can cause problems in apps, especially older carbon ports. (Blizzard's games for example have issues~) Still, typically *nix ports, especially while still on the command line tend to function case sensitively.
