Reply 20 of 32, by Warlord
This is a copy of my Dos driver files. put it in C:
You go YMFIRQ 11
Then setupDS
then LoadTSR
This is the windows VXD drivers use these
http://cdgenp01.csd.toshiba.com/content/suppo … s/t820snd95.exe
    YAMAHA.7z
    1.09 MiB
    268 downloads
Reply 21 of 32, by vorob
Dear Warlord, any chance to get you time for writing a complete step-by-step guide on how to set up sound and music in DOS? Tomorrow I'll have Toshiba Satellite 2805-S401 with Yamaha YMF754B-R and S3 Savage/IX 8Mb, and such a guide will be a time saver!
P.s. at first I thought that https://www.philscomputerlab.com/ is dead, but looks like i have to use VPN to visit if from Russia 😮
Reply 23 of 32, by Prez
Hi !
Okay i did that, everything seems okay under windows ! i could lunch Doom, DEscent, PRince of Persia, etc etc all ok !! with either GM music (very nice) or OPL3, and both with sounds, great !
But what about pure DOS games ? I still have irq problems on DOS mode, it doesn't seem there is a solution for this mode 🙁
Best regards
Philippe Dubois
Old computers and videogames freak
President of french association https://mo5.com
Get better, get old ! 😁
Reply 24 of 32, by Prez
Okay on DOS i did what you told :
For Dos.
1. You have to use the modified 810/815 driver I'll link.
2. The SET Blaster Parameters. are SET BLASTER=A220 I7 D1 T4
3. I already configured this in the driver I am going to link here. But if you use the one off Phils computer page you need to change somethings to get it to work.
4. If you use some other driver than the one for here. Be advised that the one from phils has the wrong environmental variables set up in the batch file and you need to change that.
5. To configure you go "YMFIRQ 11" without quotes at the command prompt.
6. Type SETUPDS Change it to S-IRQ and then you can change it to I7 220 D1 ETC. With the driver I will link it should already be setup for you. Then save.
7. Then to run the driver you type Loadtsr at the command prompt that's all.
But it doesn't work. In SetupDS, with S-IRQ, it doesn't recognise any IRQ i select and can't save.
Best regards
Philippe Dubois
Reply 25 of 32, by Warlord
Post screen shot of microsoft system information. And did you use the driver I linked and put it in C:\Yamaha
You can try inserting a fresh DS.INI and see if it lets you change things. That will undo the settings. in DSSETUP
    ds.ini
    353 Bytes
    66 downloads
Reply 26 of 32, by Prez
Warlord wrote on 2020-10-19, 22:51:
Hi !
First the bios settings. I did what you told about the Parallel port :
169.56 KiB
137.76 KiB
Reply 27 of 32, by Prez
Now when i try to use your files in C:\yamaha and the last ds.ini you gave :
First launch the ymfirq 11 :
95.77 KiB
Then i launch setupds.exe and i have this :
238.59 KiB
Then i change to S-IRQ and modify IRQ to 7 :
230.79 KiB
But i can't save with the typical error message :
195.13 KiB
Reply 28 of 32, by Prez
In Windows, i installed the VXD driver and changed the legacy IRQ to 7.
174.3 KiB
Every thing is working like a charm ! I can play Doom, Descent, Tie Fighter, Prince Of Persia, Dune either with OPL3 music or XG music, its great !
Reply 29 of 32, by Prez
Still no luck under MSDOS whatever i try.
I'm very interested to understand what is wrong with this computer ! 🙁
Reply 30 of 32, by AceMan
Hello, I've been messing around with my Toshiba Tecra 8200 computer for a few days trying to turn it into a gaming platform, with demoscene and AdlibTracker support. This forum has helped me solve some significant problems, so I decided to share some insights 😀
First of all - forcing games to play sound through soundblaster. I have only the newest FreeDOS installed, no Windows.
So, in my FDAUTO.BAT I have entries:
SET BLASTER=A220 I11 D1 T4
SETUPCH.EXE /s
to maintain compatibility with BIOS settings.
And I also disabled serial/paraller ports in BIOS to free IRQ 5 and 7 ports.
SETUPCH.EXE is modified SETUPDS.EXE for this particular soundcard.
SETUPCH settings are pretty standard, "INTA" mode (S-IRQ wasn't working, it was telling me that there are still some conflicts with interrupts).
With this basic setup I am able to launch Adlib-based software (like AdlibTracker2) and demos that let me choose IRQ 11 at startup.
Now for the games, the SWAPIRQ you mentioned comes to the rescue.
For some titles (Mortal Kombat 2) it is enough to change IRQ to 7.
SWAPIRQ /i11 /i7
But for most other titles, it is necessary to manually change the BLASTER variable afterwards.
So before launching the game I execute this script:
SWAPIRQ /i11 /i7
And then it works! Of course the game needs to be configured with appropiate IRQ port.
Depending on the game it can be IRQ 7 (Worms) or IRQ 5 (Warcraft, SuperFrog, Day of the Tentacle).
Hope it helps! 😀
Reply 31 of 32, by Prez
AceMan wrote on 2022-06-11, 12:29:
Hello, I've been messing around with my Toshiba Tecra 8200 computer for a few days trying to turn it into a gaming platform, wit […]
SETUPCH.EXE
SWAPIRQ /i11 /i7
SWAPIRQ /i11 /i7
Hope it helps! 😀
Great, thank you !
I will try at once 😀
Best regards
Philippe Dubois
Reply 32 of 32, by icebear
😀 its been a while, since i used my old tecra8200, today i wanted to Play monkey Island from DOS - it worked after loading the Yamaha tsr (No swapirq in this Case) and starting mi1 with
Monkey.exe v mo a
(For VGA, Mouse and adlib)
But the Midi Sounded Strange.
Just wanted to add, that IT works Well, If younstart win98 with vxd drivers First and than you Go to DOS and load the Yamaha tsr.
Have fun playing old stuff 😀
Greets
