Reply 21 of 48, by vorob
Dear Warlord, any chance to get you time for writing a complete step-by-step guide on how to set up sound and music in DOS? Tomorrow I'll have Toshiba Satellite 2805-S401 with Yamaha YMF754B-R and S3 Savage/IX 8Mb, and such a guide will be a time saver!
P.s. at first I thought that https://www.philscomputerlab.com/ is dead, but looks like i have to use VPN to visit if from Russia 😮
Reply 23 of 48, by Prez
Hi !
Okay i did that, everything seems okay under windows ! i could lunch Doom, DEscent, PRince of Persia, etc etc all ok !! with either GM music (very nice) or OPL3, and both with sounds, great !
But what about pure DOS games ? I still have irq problems on DOS mode, it doesn't seem there is a solution for this mode 🙁
Best regards
Philippe Dubois
Old computers and videogames freak
President of french association https://mo5.com
Get better, get old ! 😁
Reply 24 of 48, by Prez
Okay on DOS i did what you told :
For Dos.
1. You have to use the modified 810/815 driver I'll link.
2. The SET Blaster Parameters. are SET BLASTER=A220 I7 D1 T4
3. I already configured this in the driver I am going to link here. But if you use the one off Phils computer page you need to change somethings to get it to work.
4. If you use some other driver than the one for here. Be advised that the one from phils has the wrong environmental variables set up in the batch file and you need to change that.
5. To configure you go "YMFIRQ 11" without quotes at the command prompt.
6. Type SETUPDS Change it to S-IRQ and then you can change it to I7 220 D1 ETC. With the driver I will link it should already be setup for you. Then save.
7. Then to run the driver you type Loadtsr at the command prompt that's all.
But it doesn't work. In SetupDS, with S-IRQ, it doesn't recognise any IRQ i select and can't save.
Best regards
Philippe Dubois
Reply 25 of 48, by Warlord
Post screen shot of microsoft system information. And did you use the driver I linked and put it in C:\Yamaha
You can try inserting a fresh DS.INI and see if it lets you change things. That will undo the settings. in DSSETUP
Reply 26 of 48, by Prez
Warlord wrote on 2020-10-19, 22:51:
Hi !
First the bios settings. I did what you told about the Parallel port :
The attachment 20201020_220500.jpg is no longer available
The attachment 20201020_220508.jpg is no longer available
Reply 27 of 48, by Prez
Now when i try to use your files in C:\yamaha and the last ds.ini you gave :
First launch the ymfirq 11 :
The attachment 20201020_223144.jpg is no longer available
Then i launch setupds.exe and i have this :
The attachment 20201020_223156.jpg is no longer available
Then i change to S-IRQ and modify IRQ to 7 :
The attachment 20201020_223209.jpg is no longer available
But i can't save with the typical error message :
The attachment 20201020_223217.jpg is no longer available
Reply 28 of 48, by Prez
In Windows, i installed the VXD driver and changed the legacy IRQ to 7.
The attachment 20201020_222027.jpg is no longer available
Every thing is working like a charm ! I can play Doom, Descent, Tie Fighter, Prince Of Persia, Dune either with OPL3 music or XG music, its great !
Reply 29 of 48, by Prez
Still no luck under MSDOS whatever i try.
I'm very interested to understand what is wrong with this computer ! 🙁
Reply 30 of 48, by AceMan
Hello, I've been messing around with my Toshiba Tecra 8200 computer for a few days trying to turn it into a gaming platform, with demoscene and AdlibTracker support. This forum has helped me solve some significant problems, so I decided to share some insights 😀
First of all - forcing games to play sound through soundblaster. I have only the newest FreeDOS installed, no Windows.
So, in my FDAUTO.BAT I have entries:
SET BLASTER=A220 I11 D1 T4
SETUPCH.EXE /s
to maintain compatibility with BIOS settings.
And I also disabled serial/paraller ports in BIOS to free IRQ 5 and 7 ports.
SETUPCH.EXE is modified SETUPDS.EXE for this particular soundcard.
SETUPCH settings are pretty standard, "INTA" mode (S-IRQ wasn't working, it was telling me that there are still some conflicts with interrupts).
With this basic setup I am able to launch Adlib-based software (like AdlibTracker2) and demos that let me choose IRQ 11 at startup.
Now for the games, the SWAPIRQ you mentioned comes to the rescue.
For some titles (Mortal Kombat 2) it is enough to change IRQ to 7.
SWAPIRQ /i11 /i7
But for most other titles, it is necessary to manually change the BLASTER variable afterwards.
So before launching the game I execute this script:
SWAPIRQ /i11 /i7
And then it works! Of course the game needs to be configured with appropiate IRQ port.
Depending on the game it can be IRQ 7 (Worms) or IRQ 5 (Warcraft, SuperFrog, Day of the Tentacle).
Hope it helps! 😀
Reply 31 of 48, by Prez
AceMan wrote on 2022-06-11, 12:29:
Hello, I've been messing around with my Toshiba Tecra 8200 computer for a few days trying to turn it into a gaming platform, wit […]
SETUPCH.EXE
SWAPIRQ /i11 /i7
SWAPIRQ /i11 /i7
Hope it helps! 😀
Great, thank you !
I will try at once 😀
Best regards
Philippe Dubois
Reply 32 of 48, by icebear
😀 its been a while, since i used my old tecra8200, today i wanted to Play monkey Island from DOS - it worked after loading the Yamaha tsr (No swapirq in this Case) and starting mi1 with
Monkey.exe v mo a
(For VGA, Mouse and adlib)
But the Midi Sounded Strange.
Just wanted to add, that IT works Well, If younstart win98 with vxd drivers First and than you Go to DOS and load the Yamaha tsr.
Have fun playing old stuff 😀
Greets
Reply 33 of 48, by icebear
icebear wrote on 2020-09-06, 13:24:
Hi, just tried doom under DOS and got the same problems. Doom doesnt even start and hangs , if swapirq is present.
Anyway, doom runs fine under win98 with sound and music, if you have the vxd sound drivers installed.
greets
Just found out, that doom2 (i used Version 1.9) works in DOS, If you are using the yamaha drivers, but without swapirq.
Just Set the Blaster variable manually to IRQ11 and it works!
Set Blaster=A220 I11 D1
Reply 34 of 48, by icebear
PS: @Doom2: i Set IRQ:2 in Setup, seems Like the Blaster variable overrides the settings in setup.
In Startup doom2 says "sb Not responding" but it works anyway.
Another hint for tecra8200, playing direct3D Games in windows98:
Use Powerstrip 3.9 to disable vsync (under Performance Profile) - that helps to get acceptable Performance in Halflife and blueshift @640x480
Reply 35 of 48, by AITUS95
Hey everyone, I also have a Toshiba Tecra 8200 and I'm running into the same issues when trying to launch a game in DOS protected mode. I gave up and installed the VXD drivers on Windows 98, which let me run some games (though others need WDM drivers to work).
One game I just can't get to run is Screamer Rally—the setup won't detect my sound card at all. Any advice?
Reply 36 of 48, by theeuwke
I'm also an owner of the Tecra 8200 Laptop, with the same issue - not beeing able to remap IRQ 11, and stuck with INT#.
So I took my chances and opened up the laptop and inspected the YMF754-B:
On the YMF754
PIN 46: SERIRQ#
PIN 47: PCGNT#
PIN 48: PCREQ#
Measuring on the ICH2 side is difficult because of the package, and you'll need to disassemble the whole laptop to get beneath it.
So the problem with the Tecra, is that only PCGNT/PCREQ are connected to the ICH2-M southbrigde (for DMA), but SERIRQ# is pulled down and disconnected from the southbridge. I took the gamble, and removed the pull down and soldered a 0 Ohm (perhaps 22 ohm was safer) to the 'connection through' pads simular to the PCREQ/PCGNT - these are also connected via 0 Ohm resistors.
So far no issues, and - IRQ5 now works with S-DMA!
I also modified Phils setupds.exe ICH2 version, because the PCI-ISA Bridge PCIID is a bit different on the ICH2-M, but I don't think it make a difference.
Reply 37 of 48, by Prez
theeuwke wrote on 2025-11-11, 09:52:
I'm also an owner of the Tecra 8200 Laptop, with the same issue - not beeing able to remap IRQ 11, and stuck with INT#. […]
On the YMF754
PIN 46: SERIRQ#
PIN 47: PCGNT#
PIN 48: PCREQ#
Wow that's amazing ! so you mean that a resistor is soldered to the ground at SERIRQ or it is just soldered directly to the ground directly ?
Thank you so much for this discovery !
Best regards,
Philippe
Reply 38 of 48, by theeuwke
Prez wrote on 2025-11-12, 08:34:
Wow that's amazing ! so you mean that a resistor is soldered to the ground at SERIRQ or it is just soldered directly to the grou […]
On the YMF754
PIN 46: SERIRQ#
PIN 47: PCGNT#
PIN 48: PCREQ#
Best regards,
Philippe
What I mean is that, a stock laptop haves:
- SERIRQ from YMF754 is disconnected from the ICH2-M southbridge (pulldown on SERIRQ southbridge side is invalid, as SERIRQ is by default HIGH)
- Toshiba has placed a pull down resistor (so yeah, a resistor is soldered to the ground at SERIRQ on theYMF754 side) on SERIRQ line on the YMF754 side (for unknown reason - its not mentioned that this is needed in the YMF754 datasheet - perhaps to prevent any spurious input on that bin).
Reply 39 of 48, by Prez
So i'm not wrong, maybe you just have to MOVE the actual resistor below its actual place and it would be okay ?
