Reply 880 of 2513, by Chadti99
- Oldbie
So I got a HOT-433 version 1-3(not v4) to mess around with. I know this is Feipoa’s least favorite board but I thought what the hell, I’ll try it.
Anyway to know what version I have for certain?
I think one thing I’ve learned is that this AM5x86 CPU I have is just temperamental, one day running well on certain cache settings and the next not so much. I’ve seen this behavior on three motherboards so far and the one common factor is the CPU. I need to find a another example or two that runs well at 180.
Anyway was running 2111 cache settings on the 433 all day yesterday, boot up this morning, and it says FU when attempting Quake timedemos.
Other notes:
Using the 5H21 bios from this thread, not sure if it’s the best but I would assume so.
Success: Adding a PS/2 mouse port to the Shuttle HOT433 (using a dedicated keyboard controller chip)
DMA doesn’t work with Rendition Verite cards so far.
I can’t seem to get 1:1 PCI:FSB working at 60Mhz FSB even when using a Promise PCI IDE controller.
I’ve got a 64MB stick but it only recognizes 32MB.
Can’t seem to find the jumper settings for an AM5x86 on the V1-3 boards, I think I have it right based on the numbers I’m pulling. If you guys know where to find these let me know.
