First post, by Nemo1985
Hello fellow vogonians.
It's time for another sick motherboard comparison of mine after the ss7 fiasco because of the malfunctioning Aopen motherboard.
Cpu: Pentium 3 1000 (133x7,5)
Ram: Infineon 128mb pc133 2-2-2 (sdram) and 128mb Mosel Vitelic V58C2128804SAT7 with tightest timing (DDR)
Video card: Geforce 2 Ti 64mb (gpu: 250 mem: 400)
Hard drive: AgfaPhoto Compact Flash 8GB 233x
Windows 98 SE
Specific drivers:
Video: Detonator 3 v8.05
Intel: v3.20.1008
Sis: Agp v1.07 Ide: v2.04a
Via: 4in1443v
Motherboards:
Intel 440BX:
  • GIGABYTE 6BXC REV 2.0
  • Abit BE6-II
  • MSI BX Master
  • Asus CUBX
VIA Apollo Pro 133T:
  • QDI Advance 10T
Sis 635T
  • ECS P6S5AT (with SDR and DDR).
Test suite DOS (it's a modified\updated version of phil's pack)
3D Bench 1.0c
Chris 3D 320 & 640
PC Player 320 & 640
Doom
Quake 320 & 640
Test suite WINDOWS:
Incoming (DEMO)
Mdk2 800x600x16 TnL (demo)
3dmark99
CPU 3dmarks
3dmark2k
CPU 3dmarks
Quake 2 v3.20 modified by amd
If there is any suggestion\request and it is doable for me, I will add, remove, modify anything.
I will start the motherboard comparison tomorrow morning.
Reply 1 of 12, by flupke11
The i815 and i820 (heralded as "the best" by intel with the flagship 1.0 GHz PIII) deserve a spot as well as the Via Apollo Pro 266 DDR chipset.
I think only a few boards carry an ALI/ULI PIII chipset, but I've never seen one of these elusive boards in the wild.
I've tested the PIII chipsets available to me with the 1,4 Tualatin-S. It will be interesting to see how much the Coppermine 1Ghz fares. Enjoy the benching!
Reply 2 of 12, by Nemo1985
flupke11 wrote on 2021-04-23, 13:55:
I've always considered the i815 chipset a step back compared to the evergreen 440bx, that's why I have no motherboard with this chipset. The apollo pro 266 ddr could be interesting, unlucky again I lack a proper motherboard 😀
Reply 3 of 12, by sacri
Correct me if I'm wrong but 440BX had problems when bus was faster that 100MHz? I had P2B, P3B and some others.. running in around 150MHz always ended in corrupted files in WIN 98, WIN ME.
Using TUSL2-C with 815(p?) had not problems..
Reply 4 of 12, by Nemo1985
sacri wrote on 2021-04-23, 15:59:
Every BX board I have works fine at 133 mhz (and except for the first released motherboards, from what I read almost every bx board works at 133), the main quirk is that it lacks the proper agp divider, that could give issues with older video cards (but also give higher perfomance).
The pci has the right frequency at 133 mhz.
I never pushed my motherboards to 150, i'm not a fan of higher overclocks.
Reply 6 of 12, by Doornkaat
majestyk wrote on 2021-04-23, 20:18:
To run at 133 MHz the PCI bus would have to be PCI-X.
I believe he's talking about the FSB being 133MHz and the board having the correct divider to run PCI at the usual 33MHz.
Reply 9 of 12, by Nemo1985
So here are the results:
70.65 KiB
What to say.
I'm really undecided which motherboards to keep.
The QDI has a crippled dos performance (there is another topic talking about it here on vogons, apparently no solution, the culprit I suppose it's the Via chipset), while in windows it's not so bad (this motherboard also gave me some issues with the 3dfx v2 sli it's another known problem).
The ECS P6S5AT which is one of the best motherboards thanks to the ddr support, prove that the pentium 3 hardly needs more memory bandwidth as stating during the review of esotical chipset back in time.
About the 440bx chipset there is no a clear winner, but there is a clear looser, the Gigabyte is always a bit slower compared to Abit and MSI, the only advantage is that it has 3 isa slots.
I will try to get a 815 chipset to add it to the comparison.
Reply 10 of 12, by bofh.fromhell
Nemo1985 wrote on 2021-04-24, 18:45:
So here are the results: photo_2021-04-24_20-35-13.jpg […]
What to say.
BE6-2, CUBX and BX master are all legendary and up there when it comes to best BX boards ever.
And while I usually go for ABIT when I can, the CUBX is cool because S370 BX boards are kinda rare (and Coppermines in S370 are not).
The DDR board is a no brainer IMO, deserves a spot in any collection.
Just my €0.02 =)
Reply 11 of 12, by pshipkov
If you can get good versions of p2b-d or p3f and work them up to 1575/150 with Tualatins, that will simplify your selection process.
For reference in dos Quake1 320x200 300fps, Doom 200fps.
With p2b-d quake3 1024x768 260fps.
retro bits and bytes
Reply 12 of 12, by Nemo1985
BUMP, after 2 years let's update the comparison.
In a very unsuccessful topic, I briefly explained the difference between Abit ST6 against Asus TUSL2-C, then I decided to take them out from closet again and do the very same testing (with same configuration) as the other motherboards.
Next step if I will be ever able to find them will be to try the Intel i820 and the Apollo pro 266 motherboards.
Here is the updated chart:
202.62 KiB
