Reply 1660 of 2408, by Falcosoft
- l33t
Roland User wrote on 2024-02-13, 01:24:I want ask something else on WinMM Multi Port VSTi ) now this plugin if I selectin MIDI device , I see this as on first attachme […]
I want ask something else on WinMM Multi Port VSTi ) now this plugin if I selectin MIDI device , I see this as on first attachment ) if you remember I asked as use VBS scripting to recive MIDI ID device. I think what if recive MIDI ID from your plugin ? )
Please if this not hard add in this plugin MIDI device ID near with MIDI device name ) this will make it easier on set force MIDI ID Set for WMP )
I offer do make as second attachment
Maybe you will consider this idea )
The listed Midi Out devices are already in deviceId order (not in alphabetical or anything else). The deviceIds starts from o and ends with device count - 1.
That is: 0, 1, 2, 3, 4, ... deviceCount-1
So you can already use the list to find out the device Ids of listed devices.
Be aware that the list of 32-bit and 64-bit devices can differ on 64-bit Windows. On 64-bit Windows the default WMP is also 64-bit so you need the list of 64-bit devices (that is you should use the 64-bit plugin as help).
