First post, by MarmotaArmy
The attachment Captura de pantalla 2024-12-11 152926.jpg is no longer available
The attachment O1CN011FtbuE2B4aKSclMhw_!!61618285.jpg is no longer available
I have a 486 pc with a FIC 486-PVT motherboard , with a controller card which only supports serial mice, and I was in need to use a USB one. I found some solutions here like PS2toserial which is sold in serdashop and another PS2 isa card from RIO , but price and availability made me look if aliexpress had something and well it did.
you can query " ps2 to serial isa " in Ali's search bar to find it.
PROS:
-price (I got mine for US$ 18 + US$3 for shipping)
-It works
CONS:
-No documentation
-Odd position of the PS/2 connector (WHY??)
-No brackets
-mouse movement is ok but needs a little bit more accuracy/responsiveness (edited)
At first I was using CTmouse and couldn't get it to work , then I disabled the COM ports on the ISA IDE controller via jumpers and well nothing.... But when i bought this pc , there was a Genius mouse driver and it worked in DOS and windows 3.11. (I haven't tested it further)
It does the job but i'm wondering if I can improve accuracy , reading here I learned that maybe I should get COM speed up to 9600, and try microsoft mouse driver to increase polling rate, maybe to 100hz.
**Currently using a USB optical mouse => USBto PS2 adapter => ATEN KVM => 486 PC**
Hope this info is useful because I couldn't find anything about this adapter.
Any tips to increase accuracy? Thanks!
Reply 1 of 9, by RetroPCCupboard
Could it be the KVM that's the issue? I found Aten CS84u and CS82U to introduce unacceptable lag
Reply 2 of 9, by MarmotaArmy
It's a CS64A , I'm using it with other PCs which have PS2 ports and it's flawless.
In this case (using the ps2 to serial adapter) it's totally usable , don't get me wrong , it just needs a little bit more accuracy/responsiveness
Reply 3 of 9, by RetroPCCupboard
OK. I know some Aten KVMs are fine. Possibly the models I mentioned are OK on certain firmware levels also. Anyhow, if it isn't the KVM I wonder if it is something in how this card works that's causing lag. I thought there was some reason that PS/2 had to be natively supported by the motherboard BIOS in order to work. But the fact you were able to get it to work with a standard mouse driver I guess implies I am mistaken.
Have you tried mouse.com from MS Dos 6.22 install disks. I think that works well for me.
Reply 4 of 9, by MarmotaArmy
Not yet, I just made the test yesterday night and now posting from work! 😁
Reply 5 of 9, by Yoghoo
Got one myself as well. Good that you didn't buy the PS2toserial from serdashop as I got one of those as well but it didn't work with my KVM's. One of them is a Aten CS1784.
Also found out that a ctmouse was not working. A couple of others were working ok. I believe I'm using the Microsoft mouse driver with it (version 6.24). Mouse movement didn't seem to be a problem for me but that could also be mouse related. I am using a Microsoft PS/2 ball mouse which is not the fastest mouse to begin with but it's fast enough for the 286 which I am using with this adapter.
I created a basic bracket for it and 3D printed it. Just one with a hole in it for the PS/2 cable. In the future I'll probably just desolder the PS/2 connector and move it to the front but don't have the right PS/2 connector atm (they are available pretty cheap on Aliexpress).
Reply 6 of 9, by Cyberdyne
Usually Microsoft Mouse 8.20 is the most compatible.
Reply 7 of 9, by MarmotaArmy
I was testing againg and the lag/accuracy was due to the kvm. When using it with my computers with ps/2 ports there wasn't any.
Reply 8 of 9, by RetroPCCupboard
MarmotaArmy wrote on 2024-12-16, 21:08:
Hmm. That is odd. Possibly something with the timing of the port is causing an issue with the KVM
Reply 9 of 9, by perhenden
Cyberdyne wrote on 2024-12-12, 00:50:
Great tip! This made it work on my Socket 7 system.
My board is labeled "ISA_SERIALPORT(Ver:2.4)". I desoldered the com-port because it got in the way.
Mod to use a breakout header for the PS/2 signal:
I was hoping the left header was the 4-pin PS/2 pinout, but it was not. Not sure what it is. I desoldered the PS/2 receptacle.
The holes below it are in standard order, pin 1-6, going from left to right, down to up, so it becomes pin 2 GND nearest the PC rear of the ISA card, pin 1 CLK below it, pin 3 DATA up and right, and the top rightmost pin is pin 5 V5v. The pins are unfortunately not spaced in the 2.54mm standard pitch, so a normal header row won't fit. I soldered one pin at a time instead.
In my case I had to also connect ground to the outer ring of the new PS/2 receptacle, that's what my grey/final cable does. That last step is probably not always necessary, and depends on the model of PS/2 receptacle you are using.
