Reply 20 of 31, by User5518
- Newbie
DustyShinigami wrote on 2024-12-18, 18:30:Now that I’ve reinstalled the onboard sound drivers, this is what that mixer looks like:
So, you found, what you were looking for?
User5518 wrote on 2024-12-18, 23:55:DustyShinigami wrote on 2024-12-18, 18:30:Now that I’ve reinstalled the onboard sound drivers, this is what that mixer looks like:
No. Not the first set of drivers I used for the Yamaha that included that. It's a mystery where I got those from. I've tried searching everywhere. I'm not even sure if they were technically 'correct' for the card. Or if they were WDM.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: C, D - IDE 1, CD-ROM - IDE 2, E - IDE 3
DustyShinigami wrote on 2024-12-19, 00:06:No. Not the first set of drivers I used for the Yamaha that included that. It's a mystery where I got those from. I've tried searching everywhere. I'm not even sure if they were technically 'correct' for the card. Or if they were WDM.
Okay, yesterday, I finally managed to repair both of the floppy disk drives I have for my 440CDT. However, when I checked, the software that was installed turned out to be this:
I'm sorry. 🙁
User5518 wrote on 2024-12-19, 09:00:Okay, yesterday, I finally managed to repair both of the floppy disk drives I have for my 440CD. However, when I checked, the s […]
Okay, yesterday, I finally managed to repair both of the floppy disk drives I have for my 440CD. However, when I checked, the software that was installed turned out to be this:
I'm sorry. 🙁
Hey, don’t worry about it. Thanks for checking though. 😀 If anything, that’s brought to my attention the 440 CD. I need to look around online to see if anyone has uploaded an ISO of that disc as I didn’t get one with the PC I bought. I’m guessing that covers the 440BX, too…?
OS: Windows 98 SE
User5518 wrote on 2024-12-19, 09:00:Okay, yesterday, I finally managed to repair both of the floppy disk drives I have for my 440CDT. However, when I checked, the […]
I'm sorry. 🙁
You wouldn't happen to know if that 440 CD would work with any 440BX motherboards?
OS: Windows 98 SE
DustyShinigami wrote on 2024-12-19, 13:48:You wouldn't happen to know if that 440 CD would work with any 440BX motherboards?
I'm not sure if we're talking about the same thing. "440CD" was a typo, and I actually meant "440CDT", specifically a "Toshiba Satellite 440CDT laptop" with a "YMF715B-S" sound chip. What do you mean by "440 CD"?
User5518 wrote on 2024-12-19, 16:17:DustyShinigami wrote on 2024-12-19, 13:48:You wouldn't happen to know if that 440 CD would work with any 440BX motherboards?
Ahhhhh. Gotcha. Sorry, I thought you were referring to the motherboard driver CD for the 440BX. ^^;
OS: Windows 98 SE
I understand, okay, I need to pay better attention to what I write to avoid typos and prevent such misunderstandings.
But to answer your question in general: If one had a motherboard driver CD for a 440BX, it would very likely contain several drivers:
The drivers are, of course, always tailored specifically to the corresponding chips. That means, if a board has the respective chips, there's no reason not to use the drivers. If your board doesn't have the matching chips, you logically can't use the respective drivers. The only exception: the chipset drivers, since there's only one "Intel 440BX" chipset, and accordingly, the 440BX drivers work for all 440BX chipsets. I hope this answers your question.
User5518 wrote on 2024-12-19, 20:16:I understand, okay, I need to pay better attention to what I write to avoid typos and prevent such misunderstandings. […]
- IDE controller
- Chipset
- (possibly) audio
- (possibly) LAN
It does. Thanks. I mean, I probably don’t really need to worry about such discs, but I was curious if one existed so I could add it to my collection of drivers and software. 😀 I have some IDE drivers, so apart from that, it would only be the onboard sound drivers that would be of interest. But I most likely have the latest for those anyway.
OS: Windows 98 SE
AudioPCI 128?? That's not related to the Yamaha YMF ISA cards in any way.
badmojo wrote on 2024-12-21, 04:35:AudioPCI 128?? That's not related to the Yamaha YMF ISA cards in any way.
I know it isn’t. It’s the volume mixer utility I’m trying to find. I installed some drivers once and the mixer was identical to the ones for the AudioPCI 128.
OS: Windows 98 SE
Hi is there a way to change the opl3 volume under Windows 98? The card is Ymf744 Cobra
