First post, by root42
- l33t
I just received my OSSC and it works rather fine, but my PCs VGA text mode is cut off. The test pattern is captured nicely, but the VGA image is shifted and cropped. See the following two images, showing both the test pattern and the BIOS screen.
Can I center the image with some settings? Is there some kind of auto adjust? Same VGA card works nicely on my LCD screen.
