First post, by root42
I just received my OSSC and it works rather fine, but my PCs VGA text mode is cut off. The test pattern is captured nicely, but the VGA image is shifted and cropped. See the following two images, showing both the test pattern and the BIOS screen.
Can I center the image with some settings? Is there some kind of auto adjust? Same VGA card works nicely on my LCD screen.
The attachment A136C90F-DE37-4661-A293-876C552F5E82.png is no longer available
The attachment 712B8F0E-3576-4C15-A420-3BFFE993378F.png is no longer available
YouTube and Bonus
Reply 1 of 7, by root42
Ok, got an answer over at the OSSC forums. It seems there are advanced timing settings that one can use, but more importantly the latest firmware (0.81) already has a preset for VGA 400 line modes, which should fix this issue.
YouTube and Bonus
Reply 2 of 7, by fabiensanglard
Did you ever figure it out? I am experiencing the same problem.
Reply 3 of 7, by Tiido
You have to create a new timing profile for the resolution at hand, and it won't hurt to have the latest firmware/gateware version either.
Reply 4 of 7, by clb
If you end up creating a profile yourself, here are the most common timing geometry parameters for the 80x25 text mode:
The attachment 3.80x25-text.png is no longer available
Reply 5 of 7, by maxtherabbit
I wish we could go back and find the "clever" engineer that decided to have two modes with the exact same total line count and refresh but different pixel clocks and kick him in the dick
Reply 6 of 7, by clb
maxtherabbit wrote on 2025-01-16, 14:11:
There is a good separation 25MHz vs 28MHz between these two modes, so a device like OSSC with its ~10x faster 200 MHz Altera FPGA would definitely be able to have the Nyquist bandwidth many times over to automatically distinguish between the two.
Reply 7 of 7, by Tiido
It is still needing heuristics, you have to specifically go and try to see a difference in the active video and hopefully it has a segment where that difference can be reliably made...
But if the sync pulse was say 1 pixel shorter or longer, it would have made everyone's life a whole lot easier. One simple counter and that's all it takes to know what goes on...
