First post, by root42
I just received my OSSC and it works rather fine, but my PCs VGA text mode is cut off. The test pattern is captured nicely, but the VGA image is shifted and cropped. See the following two images, showing both the test pattern and the BIOS screen.
Can I center the image with some settings? Is there some kind of auto adjust? Same VGA card works nicely on my LCD screen.
589.47 KiB
747.85 KiB
YouTube and Bonus
Reply 1 of 1, by root42
Ok, got an answer over at the OSSC forums. It seems there are advanced timing settings that one can use, but more importantly the latest firmware (0.81) already has a preset for VGA 400 line modes, which should fix this issue.
YouTube and Bonus
