Tualatin adapter
Reply 20 of 30, by shevalier
byte_76 wrote on 2025-03-24, 16:25:
Here are the pics of the slotket and the voltage regulator.
as mentioned above, slotket does not look like Coppermine Ready.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 21 of 30, by PARKE
shevalier wrote on 2025-03-25, 11:51:
byte_76 wrote earlier:
[[The slotket supports Coppermine and I have an 850MHz in there clocked at 1130Mhz with 133FSB.]]
When I wrote 'unhealthy' I was thinking about the combination of slotket+adapter at 1400 MHz.
Reply 22 of 30, by PcBytes
I wanted to say it as well - the slotket looks Coppermine ready. The older Mendocino ones usually don't even mention FSB settings past 66 I think, let alone have 133 printed on them.
Reply 23 of 30, by byte_76
It’s absolutely Coppermine ready.
I’ve used multiple Coppermine CPU’s in that slotket and all reported correctly and worked without any issues at 100fsb and 133fsb with correct voltage in the BIOS of my P3B-F.
That said, it’s just a basic slotket and there’s certainly no guarantee that the manufacturer didn’t take shortcuts like skipping non-essential circuitry that may be required for the Tualatin to work properly.
Unfortunately I don’t have another slotket to test and eBay sellers seem to think they’re made of gold. (Unless I go for another generic item, but what would be the point of that)
Reply 24 of 30, by byte_76
PARKE wrote on 2025-03-25, 10:54:
That may mean that the korean adapter is modded to signal for 1.55volt. My suggestion is to follow riplin's earlier suggestion and set the slotket to AUTO and set the P3BF to JUMPERLESS via the JEN jumper. If that does not work then there may be something unhealty going on with the slotket or with the power delivery of the P3BF.
That slotket, btw, is a knock off of the "Super Slocket-III" wich on its turn was derived from the Maxtium CPU370 ver. 1.0.
The attachment 2a.jpg is no longer available
I’ll try this when I have a chance and report back.
Reply 25 of 30, by shevalier
If Coppermine works on the slotket, but Tualatin does not work, there is a possibility that there is no VTT connection (contacts G35-G37)
The correct Coppermine adapters have a whole polygon for VTT voltage.
As far as I remember, Copper will work without this connection, although according to the circuit design it should be there. Tualatin - definitely won't.
Reply 26 of 30, by Jasin Natael
I recently purchased one of the pin modded Tualatin's from the same seller.
I'm using one of these "Super Slocket III" adapters with mine, on an Intel Seattle SE440BX-2.
It works just fine. I would guess that the slocket is the problem.
Reply 27 of 30, by byte_76
Jasin Natael wrote on 2025-03-25, 15:05:
Which processor did you buy? (The 1.4Ghz P3?)
Can you share a pic of the pin side please?
Reply 28 of 30, by Jasin Natael
byte_76 wrote on 2025-03-25, 15:11:
I purchased one of the Pentium 1266ghz ones. The only 1.4ghz ones that he had were the Tualeron.
I'm at work and the PC is at home with the chip installed. I can probably pull it and snap a pic later if you really need it.
Reply 29 of 30, by byte_76
Jasin Natael wrote on 2025-03-25, 16:42:
If it's not too much hassle, I'd appreciate it because then I can compare his work with mine.
I would like to see which points the seller bridged and whether he removed the VID2 pin.
I am communicating with him on eBay and he has advised on some changes that may help.
Reply 30 of 30, by byte_76
I’ve found the reason for the higher CPU voltage on my Gigabyte GA-60MM7.
There is a possibly undocumented jumper next to the CPU which increases the voltage. Removing that jumper drops the voltage to just over 1.4V.
The CPU seems to work perfectly in that Gigabyte board so I guess it’s safe to assume the problem on my Asus board is either the slotket or the config of jumper/bios settings.
I haven’t had time to try the suggestions yet.
