Reply 40 of 137, by Kittyboy
- Newbie
shevalier wrote on 2025-05-03, 03:54:if you lucky enough, then just VIO module may burn out
I check both boards with power supply connected, power on. The 'coil' to the left in the image you posted on both boards is similar: .007v. The VIO from left to right is similar: .105v, Ov, 1.26v.
With computer powered on and operating for the working board:
The coil is 3.5v. The VIO from left to right is: 3.5v, 0v, 11.9v.
I have not re-installed the currently non-working board to take measurements with power on and fans operating yet. Based on this info should I continue to proceed with the non-working board to test the coil and VIO?
Still working on the pin-out for the previous cable.
Pentium III 1.4GHz-S (SL6BY), Asus TUV4X, Plextor 760A, ATI 9800 Pro, MS-DOS 6.22/Win98se dual boot
