Asus TUV4X and Pentium iii SL6BY 1.4GHz (SOLVED)
Reply 40 of 137, by Kittyboy
shevalier wrote on 2025-05-03, 03:54:
if you lucky enough, then just VIO module may burn out
I check both boards with power supply connected, power on. The 'coil' to the left in the image you posted on both boards is similar: .007v. The VIO from left to right is similar: .105v, Ov, 1.26v.
With computer powered on and operating for the working board:
The coil is 3.5v. The VIO from left to right is: 3.5v, 0v, 11.9v.
I have not re-installed the currently non-working board to take measurements with power on and fans operating yet. Based on this info should I continue to proceed with the non-working board to test the coil and VIO?
Still working on the pin-out for the previous cable.
Pentium III 1.4GHz-S (SL6BY), Asus TUV4X, Plextor 760A, ATI 9800 Pro, MS-DOS 6.22/Win98se dual boot
Reply 41 of 137, by Kittyboy
Actually I think you may have been directing I measure voltage at the base of the VIO? The measurement at the base of the working computer with power on and operating is 3.5v. (see image)
Reply 42 of 137, by myne
Slightly high, but in spec
Your have tried all slots, yes? Sometimes a slot dies.
I'll dig and see if I converted the schematic to kicad
I built:
Reply 43 of 137, by Kittyboy
myne wrote on 2025-05-03, 07:01:
Yes, all memory slots were tried with verified known to be good, operational memory. I have the luxury of having two identical side by side boards.
Attached are voltage readings as read from the connector that attaches to the board, NOT the PSU side. The pinout in the attached image is working well with my other TUV4X board based PC. I made an attempt to verify the pinout of the wire harness that originally kept my system from powering on, but when I went to install the PSU jumper it shorted and reset, so something must be pinned incorrectly in the harness? I was just trying to troubleshoot and discover how much voltage previously went to the 'wrong' place that may have caused my other board to not work?
Reply 44 of 137, by myne
https://www.chinafix.tech/asus-motherboard-tu … 1-01-boardview/
That'll save you a lot of time
I built:
Reply 45 of 137, by shevalier
There is no normal photo of TUV4X on the Internet, so I did not notice what is behind the socket.
It must be like this.
I do not know what the ACPI switch defenetly does, theoretically it switches the power from +5V standby (through some regulator) in state S3/5 to +3.3V in state S0.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 46 of 137, by shevalier
myne wrote on 2025-05-03, 08:14:
Cool, I've been looking for a long time on CUBX
Reply 47 of 137, by Kittyboy
shevalier wrote on 2025-05-03, 08:21:
Maybe this board image is better.
Reply 48 of 137, by shevalier
The easiest way to check is to bypass the VIO regulator, and this is also a factory option on simpler versions on the same PCB.
Reply 49 of 137, by Kittyboy
So, just to make sure I follow. The VIO regulator, if bad, and it appears you are very knowledgeable, could be causing the symptoms I am currently experiencing?
Long beep sequences
Black screen
Board LED light ON with fans operating
CPU warm to the touch
Basically these clues are all I have to go on currently. It's worth a try... Need to break out my soldering iron, think I might have some small gauge solid copper wire as well. So if it works, how is it actually working? You are way above my pay grade! Haha
Reply 50 of 137, by myne
A dozen things could do it.
What voltage do you see when it's beeping?
I built:
Reply 51 of 137, by shevalier
myne wrote on 2025-05-03, 12:09:
This.
The first is voltage measurement. The soldering iron is used much later.
Reply 52 of 137, by Kittyboy
shevalier wrote on 2025-05-03, 12:32:
This.
I removed the inductor and installed the jumpers, same condition exists.
Reply 53 of 137, by Kittyboy
The voltages are the same with power on the bad board compared to the measurements from the good board as measured at locations in a previous post.
Reply 54 of 137, by Kittyboy
I can check locations, any particular?
Reply 55 of 137, by Kittyboy
One new clue, I removed the BIOS and battery, still powered on the same, but no beeping.
Reply 56 of 137, by shevalier
Check this point
1. Vtt for CPU/north_bridge
2. RAM powering
Reply 57 of 137, by Kittyboy
shevalier wrote on 2025-05-03, 13:08:
Check this point
2. RAM powering
Vtt=1.24v
The other two points are = 3.31v
Reply 58 of 137, by shevalier
Last question, even without measurements.
Does the LED light up in standby mode?
It is powered from this point (the missing capacitor)
Reply 59 of 137, by Kittyboy
shevalier wrote on 2025-05-03, 13:39:
3.4v in standby mode.
