Reply 600 of 656, by Necrodude
Here is a onedrive link to the stuff
https://1drv.ms/f/c/b8c79c7b63196774/EtEat31d … 6HMQ_w?e=hyBUol
Quake3 installation
Installation:
Just drag and drop the files in your quake3 folder.
If the game for some reason decides not to start. Try another config file. Remember, if you try this, also delete the q3config.cfg file in your baseq3 folder. The autoexec file writes it info to the q3config file.
The default autoexec config file is the fastest.
This patch is also modular. You can choose if you want compressed textures or sounds.
In the Baseq3 folder and you will find different pak . You will find the following files:
pak9 - map animations This file turns of all the moving stuff on the maps.
pak9 - sounds This file includes low quality faster sounds.
pak9 - texures This file includes compressed faster textures.
pak9 - GFX This file includes compressed explosion effects etc.
If you dont want compressed textures or sounds, or any of the stuff, just remove the pak files you want.
This Patch also includes G3Virus User exe with SMP support ,and "low Quality Audio" support. Different speed configs are also included.
Quake2 installation:
Just drag and drop the files in your quake2 folder.
pak7.pak is optional. It is a low res texture pack that gives a tiny fps boost on low end machines with 4mb graphics cards
You can turn of the games textures with this variable in the autoexec.cfg file
set gl_hack_notextures "1" \\means no textures
set gl_hack_notextures "0" \\ textures on
The sound has been set to 8khz. This is a feature that cant be choosed in the menu. Less khz means more FPS
set s_khz "8"
22khz is high quality
Unreal Tournament installation:
First make a backup of your OpenGLDrv.dll that resides in the
system folder of your unreal tournament game.
Then copy the System folder to your unreal tournament folder
Start the game, choose the options menu, then, preferences, followed by
the video section.
Click on the "change" button on the video driver option.
The game restarts, a window that is called "Unreal Tournament Video Configuration" opens,
and you can change your video driver.
Press the "show all devices" button and choose OpenGL
The game restarts. You are now ready to go!
You can change a lot of settings and gain more performance or fidelity
in a hidden menu, or the unrealtournament.ini file that you will find in the system folder.
To gain acces to the hidden menu you need to do the following.
Start the game. Press the "Tools" button, followed by system console.
A window with a black background will open. Type "preferences" and the hidden menu will open.
You can change a lot of stuff here, and even brake the game.
So be careful. If you brake the game. Delete the unrealtournament.ini file in the system folder,
the game will create a new default file.
Anyway. There is video section and a renderer section with a lot of settings that you can change.
I would recomend that you read the included UTGLR Settings.html file for more info.
