First post, by joseph!
specs
pentium 3 866 mhz - 448 mb ram pc 133 reduced to 64mb via bios - motherboard Asus CUV4X-EA - 40gb maxtor HDD diamond max - built in c media cmi 8738 audio chip
iso used OS/2 warp 4.52 cp2 refresh 14.089 w4 (2 CDs)
as the title said is possible to use a 40gb HDD to install OS/2 warp 4.52? if yes, can someone explain to me howcan i do it?
this hdd has an hardware cap limit option which reduce the disk to a 8gb partition but the installation will fail/freeze during file copy or right after file copy
i also need a patch to use the built-in audio chip on OS/2 w4 if possible (c media cmi 8738)
thanks in advance
