dbellue1 wrote on 2025-08-11, 23:12:
Hello, any advice would be appreciated for installing windows 95. I have an OEM CD. I have apparently messed up 2 ssd's. After running fdisk and restarting, the boot disk just hangs at a blinking curser and does not do anything else. I have windows 95 on the hdd that came with the machine. I am guessing I formated it wrong. I made a 2gb partition and made it active on an spare ssd and the same thing happens. Since it does not boot from CD I seem to be stuck.
Does the computer fail to boot at all after creating the partition? Do you have another PC you can prepare the partitions in? That would be the most secure method.
After Fdisk, you did "format C:" from the same boot disk you got to fdisk in? Though, you might not be making it this far.
I use a 775-era computer to boot Clonezilla to clone drives, you might be able to "cheat" windows 95 onto a SSD this way as well.
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
