First post, by zuldan
- Oldbie
I managed to get this 780 Ti (https://www.techpowerup.com/gpu-specs/pny-xlr … dition-oc.b2709) for pretty cheap as it was sold "For parts". Most likely a memory chip has failed or a connection to the core from the memory chip pads. I lifted up the thermal pads for the memory but couldn't see any physical damage on or around any of them.
Time to investigate...
