Reply 160 of 168, by Señor Ventura
luckybob wrote on 2025-12-10, 20:32:i would fix the cpu running at 120mhz before I scrutinize any other test. The CD speed is actually a blessing. 8x drives run nice and quiet, having your disk spin up and down to 48x is annoying. I'd personally leave it be, unless you intend to dump 100 disks from cd to your hard drive.
Well said, i'm agree 😀
bertrammatrix wrote on 2025-12-10, 20:56:That Speedsys cpu score would be accurate even if the processor detection / frequency was not, hence I would trust it is running at 120mhz
No wonder you have low performance for a 200, if it's not a 200 😀 Should it be? Ie does it have a 200 CPU inserted?
Yes, i put a pentium 200 in it. Originally was a pwnrtium 120, and i swapped the processors, but bios and benchmarks still sees the pentium 120... and i don't know how to change it.
