First post, by DustyShinigami
Has anyone encountered this or knows of a way to fix it...? I've had this issue happen with two games so far - Gabriel Knight 3 and Quake 2.
Basically, the games install WAY too fast using my virtual CD drive and the CD images, that they either fail with an error during the installation or when trying to load the game. With Quake 2, it's supposed to be around 400MB, but after every install it's only around 100MB. It seems to have problems copying the pak0.pak file. This hasn't been an issue before, so it's only very recently that it's started doing it. I've tried setting the speed of the virtual drive to be 2x, 4x, and 8x, but it still remains too fast. I've tried both CDSlow and Nero DriveSpeed 3.00. The physical CD drive isn't a problem. That gets set to the chosen speed and the game installs perfectly fine.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1 of 15, by DustyShinigami
For Gabriel Knight 3, it isn’t a problem to install from the physical CD and then run the game with the image. It doesn’t complain about the source/paths being wrong. With Quake 2 though, it is an issue. Nothing loads or plays correctly. Especially the redbook audio.
I’ve checked through the files and the registry editor to see if I can change the source/drive letter, but can’t find anything. So I’m not quite sure what to do with this one.
OS: Windows 98 SE
Reply 2 of 15, by Shagittarius
I install from a networked drive and haven't seen that issue. Is the Disc mounted directly on the System in question?
Unless the rips are done wrong, or there is some form of copy protection as long as your CD is mounted at the same drive letter it was installed from I do not think there should be these issues normally.
Reply 3 of 15, by zapbuzz
some things I'd like to know
- operating system
- virtual drive brand and version
- have you verified the disc image if iso 7-zip can do that
Some games require the virtual drive letter to be before any other optical alphabetical address to work
Reply 4 of 15, by NeoG_
I assume from previous comments you are storing your images on a second drive. Can you make a fresh image directly on the OS drive and use that to install a game? To rule out any shenanigans in the underlying storage
If that works then copy one of the "non working" images from the secondary drive to the OS drive and see if that works
I figure something will pop up during testing. If all fails then the software is probably bugged out and needs to be reinstalled.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 5 of 15, by DustyShinigami
Shagittarius wrote on Yesterday, 22:56:
I networked drive? Like what DaveDDS suggested to me where you use a local network between the retro PC and the main PC? Or is that something different?
Well, to make sure, I re-created the image on my main PC with Imgburn. Everything seems to be in order. I’m also not 100% if the Quake 2 disc has copy protection. I’m not even sure about GK3’s first disc, though I did try CloneCD with that and still had an issue during install.
If I install Quake 2 from the physical CD then the drive letter will be different. And yet with GK3 it doesn’t seem to be an issue; it accepts the mounted image when loading/playing. But for Quake 2’s image, the installer goes far too quickly.
OS: Windows 98 SE
Reply 6 of 15, by DustyShinigami
I can’t reply to the other posts yet as I’m about to head to work, so I’ll answer the other questions later.
OS: Windows 98 SE
Reply 7 of 15, by DustyShinigami
zapbuzz wrote on Today, 03:41:
some things I'd like to know […]
- operating system
OS: Windows 98 SE.
VD: It's the one from Alcohol 120%. It's listed as an SCSIVAX CD/DVD-ROM
Quake 2 has redbook audio, so it's a BIN and CUE file. Not sure if 7Zip can verify those...?
It's set before the physical CD drive. It's G and the physical, H.
OS: Windows 98 SE
Reply 8 of 15, by DustyShinigami
NeoG_ wrote on Today, 04:01:
Well, I've included my previous 80GB HDD too, so I can store image backups of the C drive and just for any general data storage. So I have C (Windows), D (games), E (CD images), and D (backups). I think I did create a new image under 98, though it was saved to the E drive. I can try re-doing it on the C drive and see what happens. And copying it from E to C.
The first thought that came to mind is the E drive (Deathstar) could be the culprit, but only two games have had this issue so far. I have got some more games to install, so we'll see if there are any others.
OS: Windows 98 SE
Reply 9 of 15, by douglar
Is this the same computer with the questionable storage subsystem that we've talked about a lot in Advice on bigger HDDs beyond 128GB ?
If so, I think the root problem goes back to the questionable storage subsystem.
Reply 10 of 15, by DustyShinigami
douglar wrote on Today, 13:47:
Eh-heh, yeah, it is. ^^; I'm guessing a change of HDD wouldn't make any difference...? If there's some underlying issue elsewhere?
OS: Windows 98 SE
Reply 11 of 15, by DustyShinigami
Yeah, so copying an image from one drive to another isn't a problem. The problem is copying the contents of the image. Even after it's been copied to the C drive, mounted, and the cotents copied and pasted to C, whenever it gets to pak0.pak, it gives an error saying 'Cannot copy pak0. The system cannot read from the specified device.'
OS: Windows 98 SE
Reply 12 of 15, by douglar
DustyShinigami wrote on Today, 14:01:
It still sounds like the geometry on your drives is screwed up somehow or not all the bits of the storage addresses are making it to the drive. Things work fine for a while working inside the first few GB of each drive, but eventually something happens as you get farther into the storage where writes folds over and end up on top of existing files or the writes go off into nowhere land and are not preserved.
Reply 13 of 15, by DustyShinigami
douglar wrote on 53 minutes ago:
Hmm. Sounds plausible. I won't pretend in understanding completely what goes on under the hood, but something is definitely off somewhere. It's finished creating another image of the game's disc on the C drive. It copies the pak0.pak file without issue, but only through copy and paste. Installing it is another matter though. The installer still goes by too quickly and especially when it gets to that file. The maximum install should be 400MB and it only winds up as 100MB by the end. 🙁
OS: Windows 98 SE
Reply 14 of 15, by DustyShinigami
What would be the best solution? Are there tests I can run? Would I need to replace all the hard drives? Reformat? I'm not sure what to do.
OS: Windows 98 SE
Reply 15 of 15, by douglar
DustyShinigami wrote on 28 minutes ago:
I'd be interested to know if win9x uses MS-DOS compatibility mode on your system. Open Control Panel > System > Performance. If your drives are in compatibility mode, you will see a messages like "Drive X is using compatibility mode file system"
The attachment 2.jpg is no longer available
If you see that, it means that when Windows started, it detected something unexpected and didn't try to enable protected mode drivers.
