First post, by Shiftyy
I am building an ultimate DOS/98/XP machine unlike any that has been done before (afaik).
The plan is to cover games from the late 80s up to the mid-late 2000s.
In one example, the machine can play CoD4 at very playable framerates. I recently participated in a LAN event with the settings almost at max but running 1024x768 resolution. The system performed at a stable 100+ FPS, and was usually locked at the 125 FPS cap most of the time.
It is a work in progress.
Case: Gateway LP Mini Tower TB3 Performance 750
Motherboard: ANOVO AIMB-865 Revision v1.02
CPU: Intel Core 2 Extreme X6800 @ 3.2Ghz (800 FSB)
CPU Cooler: Thermaltake ISGC-400
PSU: Antec TruePower 2.0 430W (Recapped)
FDD: Gotek USB Floppy Emulator (SFRM44-U100LQD-435)
Memory: Mushkin Enhanced Blackline 2GB (2 x 1GB) DDR 400 Dual Channel Model 991434 (2-3-2-5)
SSD #1: 128GB Generic SSD for DOS & Win98
SSD #2: 256GB Generic SSD for WinXP
GPU #1: Sapphire Radeon HD 3850 512MB GDDR3 AGP + AGPSX4-V Extender from ADEX Electrontics
GPU #2: 3D Fuzion GeForce FX 5500 256MB DDR PCI 3DFR55256P Overclocked to 300Mhz GPU 450Mhz Memory
Sound Card #1: Creative Sound Blaster Audigy 2 ZS PCI (SB0350)
Sound Card #2: Gravis Ultrasound Classic ISA (Rev 3.74)
Sound Card #3: Creative Sound Blaster AWE32 ISA (CT3900)
Sound Card #4: PCMIDI MPU-401 ISA
WaveTable #1: DreamBlaster X2GS SE (Connected via AWE32)
WaveTable #2: WP32 McCake (Connected via PCMIDI MPU-401)
Bootloader: GRUB4DOS
OS #1: DOS 6.22
OS #2: Windows 98 SE
OS #3: Windows XP SP3
Monitor: Dell UltraScan P1100 21" CRT Overclocked to 135Khz Horizontal Refresh
Keyboard: FILCO Majestouch 3 FKBN104M/EMB3-AKP Cherry MX Brown N Key Rollover (Connected via USB>PS2 adapter)
Mouse #1: Microsoft Pro IntelliMouse
Mouse #2: Microsoft IntelliMouse Optical 1.1A Black (Connected via USB>PS2 adapter)
Speakers: Roland Cakewalk MA-15D Black
Planned changes/improvements:
Two Voodoo 2s in SLI
N̶o̶c̶t̶u̶a̶ ̶N̶H̶-̶C̶1̶4̶S̶ ̶C̶P̶U̶ ̶c̶o̶o̶l̶e̶r̶
̶O̶v̶e̶r̶c̶l̶o̶c̶k̶ ̶x̶6̶8̶0̶0̶ ̶t̶o̶ ̶4̶G̶h̶z̶ ̶o̶r̶ ̶a̶b̶o̶v̶e̶ ̶(̶R̶e̶q̶u̶i̶r̶e̶s̶ ̶v̶o̶l̶t̶ ̶m̶o̶d̶)̶
ThrottleBlaster implementation to support speed sensitive DOS games
Upgrade/swap HD 3850 cooler to HD 3870 cooler
PicoIDE to replace one of the CD drives
2GB > 4GB RAM (Maybe)
