First post, by Shiftyy
The attachment 743312319_10231450925967238_2405643990420530943_n.jpg is no longer available
The attachment 743276574_10231450930047340_3005510021967968429_n.jpg is no longer available
The attachment 20260622_151741.jpg is no longer available
I am building an ultimate DOS/98/XP machine unlike any that has been done before (afaik).
The plan is to cover games from the late 80s up to the mid-late 2000s.
In one example, the machine can play CoD4 at very playable framerates. I recently participated in a LAN event with the settings almost at max but running 1024x768 resolution. The system performed at a stable 100+ FPS, and was usually locked at the 125 FPS cap most of the time.
It is a work in progress.
Case: Gateway LP Mini Tower TB3 Performance 750
Motherboard: ANOVO AIMB-865 Revision v1.02
CPU: Intel Core 2 Extreme X6800 @ 3.2Ghz (800 FSB)
CPU Cooler: Thermaltake ISGC-400
PSU: Antec TruePower 2.0 430W (Recapped)
FDD: Gotek USB Floppy Emulator (SFRM44-U100LQD-435)
Memory: Mushkin Enhanced Blackline 2GB (2 x 1GB) DDR 400 Dual Channel Model 991434 (2-3-2-5)
SSD #1: 128GB Generic SSD for DOS & Win98
SSD #2: 256GB Generic SSD for WinXP
GPU #1: Sapphire Radeon HD 3850 512MB GDDR3 AGP + AGPSX4-V Extender from ADEX Electrontics
GPU #2: 3D Fuzion GeForce FX 5500 256MB DDR PCI 3DFR55256P Overclocked to 300Mhz GPU 450Mhz Memory
Sound Card #1: Creative Sound Blaster Audigy 2 ZS PCI (SB0350)
Sound Card #2: Gravis Ultrasound Classic ISA (Rev 3.74)
Sound Card #3: Creative Sound Blaster AWE32 ISA (CT3900)
Sound Card #4: PCMIDI MPU-401 ISA
WaveTable #1: DreamBlaster X2GS SE (Connected via AWE32)
WaveTable #2: WP32 McCake (Connected via PCMIDI MPU-401)
Bootloader: GRUB4DOS
OS #1: DOS 6.22
OS #2: Windows 98 SE
OS #3: Windows XP SP3
Monitor: Dell UltraScan P1100 21" CRT Overclocked to 135Khz Horizontal Refresh
Keyboard: FILCO Majestouch 3 FKBN104M/EMB3-AKP Cherry MX Brown N Key Rollover (Connected via USB>PS2 adapter)
Mouse #1: Microsoft Pro IntelliMouse
Mouse #2: Microsoft IntelliMouse Optical 1.1A Black (Connected via USB>PS2 adapter)
Speakers: Roland Cakewalk MA-15D Black
Planned changes/improvements:
Two Voodoo 2s in SLI
N̶o̶c̶t̶u̶a̶ ̶N̶H̶-̶C̶1̶4̶S̶ ̶C̶P̶U̶ ̶c̶o̶o̶l̶e̶r̶
̶O̶v̶e̶r̶c̶l̶o̶c̶k̶ ̶x̶6̶8̶0̶0̶ ̶t̶o̶ ̶4̶G̶h̶z̶ ̶o̶r̶ ̶a̶b̶o̶v̶e̶ ̶(̶R̶e̶q̶u̶i̶r̶e̶s̶ ̶v̶o̶l̶t̶ ̶m̶o̶d̶)̶
ThrottleBlaster implementation to support speed sensitive DOS games
Upgrade/swap HD 3850 cooler to HD 3870 cooler
PicoIDE to replace one of the CD drives
2GB > 4GB RAM (Maybe)
Reply 1 of 32, by Shiftyy
I am utilizing the Gravis Ultrasound's ISA expansion pins to add an additional ISA slot since I need three and the motherboard only has two.
This is a proof of concept to confirm that everything works as intended (It does). I have a custom circuit board and cable on the way to make the install much neater and less janky.
The attachment 20260702_231722.jpg is no longer available
The attachment 20260702_233234.jpg is no longer available
The attachment 20260702_233242.jpg is no longer available
Reply 2 of 32, by Shiftyy
Here is the CPU cooler I will be upgrading to that will hopefully allow me to achieve a 4Ghz+ overclock at decent temps.
The attachment 20260703_010811.jpg is no longer available
The attachment 20260703_010806.jpg is no longer available
I plan to perform this VID/Volt mod on the x6800 CPU to increase the voltage from 1.325 to 1.45. It will require conductive paint and kapton tape.
The attachment 3.jpg is no longer available
Reply 3 of 32, by Shiftyy
Here is the heart and soul of the build. ANOVO AIMB-865 v1.2. It supports Core 2 Duo and ISA DMA. It is a very unique motherboard.
The attachment 1-1 copy.jpg is no longer available
I have performed a BSEL modification which forces the CPU to run at 200 FSB instead of 100 FSB, which is required due to a flaw with the motherboard.
The attachment 8GT3Jf3.png is no longer available
Another flaw with this motherboard is the memory slots are located directly in-front of the AGP slot. An AGP extender/riser is required if you want to insert a long AGP card.
The attachment 79uVKYC.jpeg is no longer available
The attachment c0zEf0O.jpeg is no longer available
The attachment MlS5OMr.jpeg is no longer available
Reply 4 of 32, by Shiftyy
I originally had a 21" Gateway Vivitron 1100 CRT monitor and wanted to pair it with a Gateway case, which is the reason for choosing the LP Mini Tower TB3 Performance 750.
Unfortunately that monitor died whilst building this PC, but I have stuck with the case because I love the looks and it gives a retro vibe.
The case has a permanent rear IO backplate/shield and requires a proprietary power supply, so some modifications with a dremel was required.
The attachment 20251222_191220.jpg is no longer available
The attachment 20251222_191232.jpg is no longer available
The attachment 20251222_191250.jpg is no longer available
The attachment 20251223_183503.jpg is no longer available
The attachment 20251223_184238.jpg is no longer available
Reply 5 of 32, by Shiftyy
The attachment 20260125_142056.jpg is no longer available
The attachment 20260125_142038.jpg is no longer available
The attachment 20260125_142139.jpg is no longer available
The attachment 20260125_203856.jpg is no longer available
Reply 6 of 32, by Mao
Thanks for sharing your project and your future plans. I could benefit from your ideas!
Reply 7 of 32, by RetroPCCupboard
That motherboard containly seems like a bit of a unicorn. Interesting build.
Reply 8 of 32, by NeoG_
Extending the ISA bus using an Ultrasound is something I didn't expect but respect
Reply 9 of 32, by geordiepingu
When I read the thread title, I did think "Not yet another 775 'Ultimate Win98 build'". I'll give you your dues; that is an absolutely fascinating motherboard, and it does actually try to leverage some proper period hardware. Interested to see how you get on with the Voodoo 2s; I had thought about running mine in another rig with an FX5500 but now use them in my little 1100Mhz "Celerowned rig" with an IntelIGP.
Nice build!
geordiepingu wrote on 2026-07-05, 17:19:
All for the benchmarks!
Petrol head and serial PC tweaker
Reply 10 of 32, by gerry
geordiepingu wrote on 2026-07-14, 08:32:
Nice build!
yes, and if it was me, i'd be tempted to add a win 7 OS too - why not 😀
Reply 11 of 32, by Shiftyy
RetroPCCupboard wrote on 2026-07-13, 21:48:
I believe it might be the fastest board with ISA DMA support, not counting those that use LPC-ISA like the Portwell RUBY-9719VG2AR or dISAppointment adapter. I believe those using LPC-ISA have more compatibility issues, which this board doesn't suffer from, except for GUS PnP which is known to have issues with most ISA boards that support Pentium 4 onward.
NeoG_ wrote on 2026-07-14, 01:21:
I wanted the following:
Real OPL3 (Awe32)
Emu8k (Awe32)
SC-55 (X2GS)
MT-32 with intelligent mode support (PCMIDI + McCake)
Gravis Ultrasound
Whilst keeping everything internal (No external MIDI devices).
I don't think I can achieve this with two ISA slots, unless I use an Awe32 + PicoGus. But I wanted to avoid using a PicoGus because I didn't want to worry about switching profiles. Plus this implementation makes the PC very unique imo. You don't see a lot of people adding a third ISA slot via a Gravis Ultrasound 🤣.
Nice build!
Thanks. The Voodoo 2s will probably be the last thing I implement into the build. I didn't have a 3dfx card growing up so I don't hold much nostalgia for them. However adding them will fill all the available PCI slots and make the build much cooler, so it must be done. My wallet will not be happy though ;(
gerry wrote on 2026-07-15, 08:15:
Unless I can figure out a good reason, I will probably stay away from Win7. There's nothing to gained from it.
Reply 12 of 32, by Shiftyy
I have finished implementing a less janky way of adding a third ISA slot. I'm very happy with the end result. How neat does it look!
The attachment 20260714_153140.jpg is no longer available
The attachment 20260714_180408.jpg is no longer available
The attachment 20260714_182312.jpg is no longer available
The attachment 20260714_182445.jpg is no longer available
The attachment 20260715_230730.jpg is no longer available
Reply 13 of 32, by King Wajih
Well if you somehow up the ram to 4GB, find a Radeon HD 4670 1GB GDDR3, OC that processor & install Win Vista or 7 x64 you might be able to get away with running Grand Theft Auto V on low settings at 1024x768. It ain't gonna be pretty but its gonna be real head-turner at retro Lan parties. Also you should consider Win 7 if you wanna browse the modern web and watch YouTube(Although mypal68 could do that too). These GPUs can decode H.264(if blacklist is ignored) so 1080p@30fps or 720@60fps Youtube is entirely possible via enhanced-h264ify.
Tbh this pc kinda gives off the same vibe as the hover conversion for the Delorean from Back to the future.
Reply 14 of 32, by TELVM
Fascinating machine. 👍
file.php?mode=view&id=245855
^ Beware the Antec Truepower 2.0 was stuffed full of Fuhjyyu crapacitors. These infamous PSUs were already dropping like flies ~20 years ago ...
Let the air flow!
Reply 15 of 32, by Shiftyy
King Wajih wrote on 2026-07-17, 22:30:
The HD 4670 would be a downgrade compared to the HD 3850 for most games and I don't have a desire to use it for media consumption. Plus I heard that 1GB VRAM might be problematic for Win98, even though there's no drivers. Also the HD 4670 requires two slots so I wouldn't be able to do SLI Voodoo 2s in the future.
At this stage, my intentions are to strictly use the machine for retro gaming.
I don't think there's anything to be gained by trying to run modern titles such as GTA5 as I'd be much better off running that on a modern PC. I'm not looking to chase that sort of clout at the LAN parties either.
Don't get me wrong, I appreciate your feedback. I just don't see a reason for Win7 or higher, gaming wise. I'm happy to be proven wrong though.
TELVM wrote on 2026-07-17, 23:53:
Fascinating machine. :+1: […]
Thanks for the warning. I actually did perform a recap on the PSU, so it should last a long time =)
Reply 16 of 32, by AlexZ
Looks great.
Don't expect wonders from ATI Radeon HD 3850 AGP, I think it will struggle in Quake 4.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 17 of 32, by Shiftyy
AlexZ wrote on 2026-07-18, 07:19:
Looks great.
It can run Quake 4 at max settings with no worries. It's a card from 2007.
Reply 18 of 32, by TELVM
Shiftyy wrote on 2026-07-18, 05:31:
... I actually did perform a recap on the PSU, so it should last a long time =)
^ Cool 👍 . I was expecting this, no other way for a Truepower 2.0 to remain operational @ 2026.
Let the air flow!
Reply 19 of 32, by NeoG_
Shiftyy wrote on 2026-07-12, 07:05:
If you are interested in making your WP32 McCake sound more like an SC-55 in soundfont mode, I recommend Trevor0402's SC-55 soundfont
https://www.doomworld.com/forum/topic/118828- … comment-2493425
And I made a patched version of mt32-pi for the WP32 which rolls in the SC-55s specific percussion behaviour (which the dreamblaster GS series doesn't replicate)
Getting SC-55 style drum note cut behaviour on MT32-Pi Fluidsynth
