Reply 240 of 780, by James-F
 - Oldbie
Many instruments like Organ and Harpsichord don't respond to velocity changes because the real instrument also doesn't.
This is not related to SC-VA but a general question about midi, you are probably at the wrong forum with these questions.
Clarify what? Different SC units sound different, what's your point? (don't answer, both are rhetorical questions).  😒
I don't care what SC unit you think Comanche 3 (or any other game) was written on, and so does Roland Corporation.
Stop asking me to ask Roland with your nonsense, I will do so only if I think it's right.
Give this subject a rest.
Here you can see what SC units support General Midi 1 (GM): https://en.wikipedia.org/wiki/Roland_Sound_Canvas
Under the Standards column, if you see GM it means that this specific unit fully supports GM.
With SC units of the past the user could select different Map Modes even in GM.
