DOSBOX fork with better FM synthesis?
General information and assistance with DOSBox.
Re: DOSBOX fork with better FM synthesis?
Postby James-F » 2016-8-15 @ 15:55
Sorry, can't hear it.
Anyway, I'm defaulting to Fast in oplemu till dosbox devs decide to implement Nuked OPL... "wink, wink"
User avatar
James-F
Postby KainXVIII » 2016-8-15 @ 17:19
Can anybody spot the difference?
Ween_fast.mp3
(4.57 MiB) Downloaded 61 times
Ween_nuked.mp3
(4.47 MiB) Downloaded 59 times
User avatar
KainXVIII
Postby James-F » 2016-8-15 @ 18:14
I can't.
Can you hear the difference nukeykt posted of Aladdin between Fast and Nuked??
User avatar
James-F
Postby Stiletto » 2016-8-15 @ 19:03
YMF718 is a good comparison? Why not recording YM3812 or YMF262 in DOS/Windows? :)
do the Fandango!" - Queen
Stiletto
User avatar
Stiletto
Postby Scali » 2016-8-15 @ 21:28
Stiletto wrote:YMF718 is a good comparison? Why not recording YM3812 or YMF262 in DOS/Windows? :)
Agreed, real AdLib and SB Pro v2 only! :)
Scali
Postby James-F » 2016-8-16 @ 04:05
Why, YES.
By all means go ahead.
User avatar
James-F
Postby evgs » 2016-8-16 @ 22:49
I hear difference in "arrock1"
Piano-like synth (0:31 - 0:51) sounds much brighter and louder on YMF718 compared to all four OPL-emulation cores.
Does not look like the 3d effect the only reason of this.
Interesting to listen YM3812 or YMF262.
User avatar
evgs
Postby Stretch » 2016-8-16 @ 23:30
How do I play the midi with the OPL chip on my YMF-744? When I play it the XG synthesis is used.
PC1: Win98SE - Via Apollo Pro Mobo - Pentium II 233 - 256 MB - Voodoo 3 1000 - Soundblaster 32
PC2: Win98SE - ASRock 775i65G R3.0 - Celeron 2.2 GHz - 2048 MB - Geforce FX5700 - Vortex 2 - SBLive SB0100 - YMF744
Stretch
Postby James-F » 2016-8-17 @ 03:49
Falscosoft Midi Player supports windows 9x and on, and it's the best and most feature packed midi player I know of. viewtopic.php?f=5&t=48207
You can select the midi output to Soft, FM, MPU-401, Soundfonts, etc. right from the midi player options (select FM).
Please disable any 3D effects from Control Panel or Volume Control in Windows 9x before recording and Bass/Treble should be set to 0 on the YMF71x for flat and accurate recording.
Can you hear the difference between the four excluding the terrible YMF718 recording?
The 3D effect might make some instruments louder/fuller than others and it completely destroys the stereo image, you can disregard the ymf718 recordings posted by nukeykt.
The 3D effect that the YMF718 applies is so bad the recordings of the ymf718 nukeykt posted should NOT be reference to anything at all.
nukeykt, please re-record your example WITHOUT the 3D effect because this is terribly misleading.
I'd like it too, but nobody seems up for the task.
User avatar
James-F
Postby nukeykt » 2016-8-17 @ 09:30
Just recorded samples from YMF262 OPL3:
lion10-ymf262.mp3
lion10.mid YMF262 OPL3
(2.04 MiB) Downloaded 48 times
arrock1-ymf262.mp3
arrock1.mid YMF262 OPL3
(2.8 MiB) Downloaded 50 times
nukeykt
Postby James-F » 2016-8-17 @ 13:55
First, thank you very much for the YMF262 tracks.
It is obvious that NukedOPL is the most accurate of the bunch, it is spot on the YMF262.
User avatar
James-F
Postby nukeykt » 2016-8-17 @ 14:19
For ymf718 i used windows media player and yamaha's sound card drivers installed in windows 98se.
For emulators i used windows media player and opl3 user mode driver in windows 10.
For ymf262 i used same user mode driver and sweet midi player in windows 10.
Also note that Windows 98 has two opl3 drivers: one for sound blaster cards and second is generic driver. They slightly differ: Volume calculation table differ, generic fm driver doesn't support MIDI sustain and seems has bug where one note doesn't play in lava3.mid from gubble 2. Ymf718 uses generic driver, while my user mode driver replicates sb16 driver.
nukeykt
Postby James-F » 2016-8-17 @ 14:35
nukeykt wrote:For ymf262 i used same user mode driver and sweet midi player in windows 10.
But, it is not a real YMF262?
To record my YMF719E I used a midi output called "OPL3-SA FM MIDI" which I think is part of the Yamaha YMF driver for windows98SE.
User avatar
James-F
Postby nukeykt » 2016-8-17 @ 14:42
James-F wrote:But, it is not a real YMF262?
I built Arduino based OPL3 rig and modified user mode driver to send OPL commands to Arduino.
This how i recorded it:
Sweet MIDI Player->User Mode OPL3 driver->Arduino->Yamaha YMF262-M(OPL3)->Yamaha YAC512M(DAC)->Line in->Audacity->MP3.
Now i'll record samples using original drivers running in modified DOSBox-X and OPL3 rig.
nukeykt
Postby nukeykt » 2016-8-17 @ 15:12
Here's samples:
lion10-ymf262-sb16.mp3
SB16 FM driver
(2.07 MiB) Downloaded 35 times
lion10-ymf262-msopl.mp3
Generic FM driver
(2.05 MiB) Downloaded 32 times
arrock1-ymf262-sb16.mp3
SB16 FM driver
(2.86 MiB) Downloaded 32 times
arrock1-ymf262-msopl.mp3
Generic FM driver
(3.11 MiB) Downloaded 32 times
nukeykt
Postby James-F » 2016-8-17 @ 15:25
They sound the same to my ear.
User avatar
James-F
Postby nukeykt » 2016-8-17 @ 15:51
James-F wrote:They sound the same to my ear.
I still don't understand why the YMF719 sounds different to all others starting from second 18 on the lion track, It uses the exact same YMF289 chip like the YMF718?
That particular instrument sounds mellower and less modulated on the 719 than on the 718 or any other OPL you posted.
Your older sample seems good to me. But newer is strange.
nukeykt
Postby James-F » 2016-8-17 @ 15:58
It's the exact same file reposted.
Can you please record again the YMF718 without the 3D effect?
User avatar
James-F
Postby nukeykt » 2016-8-17 @ 16:02
I think this is bug related to Tremolo generator. I got similar problem with CMI8738's FM synth, which seems is perfect OPL3 clone. Try to reboot your pc.
nukeykt
Postby nukeykt » 2016-8-17 @ 16:04
Sorry. But i still can't find option which disables 3D.
nukeykt
PreviousNext
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 3 guests
