Reply 540 of 895, by Peixoto
- Member
wrote:Hello Peixoto, I'm having trouble using your injector with Little Big Adventure (LBA). […]
* Playing LBA through LbaWin 0.8.1.
* Installed using the EU version of LBA.
* Using the most recent version of your injector (updated 2019-5-22).
* Any combination of injected settings (xBR scaler, looping music, compatibility options, plugged-in gamepad) causes the issues mentioned below.The issues I'm having:
* The entire screen is blacked out from the moment the starting Adeline Software logo appears, up until the main menu (can still hear the music/sound effects of the opening logos/cinematics).
* At the main menu, creating a save file (even naming it "auto", as your new save system recommends) or loading a pre-existing save file immediately results in a hang and CTD.Here is the accompanying error log:
CreateProcessA Hook: 0
CreateProcessW Hook: 0
Succeeded to create the DirectSound interfaces
Desktop 1920x1080
OpenAdapter Hook 0
DDraw.dll : C:\WINDOWS\SYSTEM32\DDRAW.dll
DirectDrawCreate Hook : 0
Succeeded to create DirectDraw
Succeeded to create Direct3D
Succeeded to hook IDirectDraw2::CreateSurface
Succeeded to hook IDirectDraw::CreateSurface
Succeeded to hook IDirectDrawSurface::restore
Succeeded to hook IDirect3DDevice::EndScene
Succeeded to hook IDirect3DDevice::AddViewport
Succeeded to hook IDirectDraw::EnumDisplayModes
Succeeded to hook IDirectDraw::SetDisplayMode
Succeeded to hook IDirectDraw2::SetDisplayMode
Succeeded to hook IDirect3DViewport::SetViewPort
Succeeded to hook IDirect3DViewport::GetViewPort
Succeeded to hook IDirect3DViewport::Clear
Succeeded to hook IDirect3DDevice::Execute
Succeeded to hook IDirectDrawSurface::flip
Succeeded to hook IDirectDraw::GetDisplayMode
Succeeded to hook IDirectDrawSurface::QueryInterface
Succeeded to hook IDirectDrawSurface::GetPixelFormat
Succeeded to hook IDirectDrawSurface::GetSurfaceDesc
Succeeded to hook IDirectDrawSurface::GetDC
Succeeded to hook IDirectDrawSurface::ReleaseDC
Succeeded to hook IDirectDrawSurface::GetPalette
Succeeded to hook IDirectDrawSurface::SetPalette
Succeeded to hook IDirectDrawPalette::SetEntries
Succeeded to hook IDirectDrawPalette::GetEntries
Succeeded to hook IDirectDrawSurface::Bltfast
Succeeded to hook IDirectDraw::SetCooperativeLevel
Succeeded to hook IDirectDraw2::SetCooperativeLevel
So far, so good
CreateFile Hook : 0 <- 0 means no error
CloseHandle Hook : 0 <- 0 means no error
I hope that this is fixable, as playing LbaWin with a gamepad would be great. Thanks for reading.
Your log is incomplete. Post the role thing.
Open scripts\lba with a text aditor and delete these lines:
logerr("CreateFile Hook : " InstallHook("LbaCreateFileA", pOpenFileA, "Kernel32.dll", "CreateFileA") " <- 0 means no error")
logerr("CloseHandle Hook : " InstallHook("LbaCloseHandle", pCloseHandle, "Kernel32.dll", "CloseHandle") " <- 0 means no error")
logerr("DeleteFile Hook : " InstallHook("LbaDeleteFile", pDeleteFile, "Kernel32.dll", "DeleteFileA") " <- 0 means no error")
that should solve the hanging, but you will only have the regular save system
Then change
Alt_blt(p1, p2, p3, p4, p5, p6)
to
__Alt_blt(p1, p2, p3, p4, p5, p6)
that should save the black screen
wrote:So, the zooming issue for Tomb Raider 2, 2 Gold, 3, and 3 Gold is still prevalent in this new version. I have the trace file, but this website won't let me upload it. Any other way I can get it to you?
https://1drv.ms/u/s!ApHOE-Ru-xkG5VkiNUkN_3MZd5RI
Try version one. Its the oldest i have
Upload your trace file somewhere else
wrote:...
HyperBlade DPI scaling settings should be handled. Try the latest version, and if it doesn't work post your log
Army Men RTS (Demo) It works now. DirectX 7
Total Annihilation: Kingdoms (Demo) Also works, but has some tilling issues on some bitmaps. DirectX 6, needs the "fix window size" option. 1st purely directdraw DirectX 6 game i tried, i'll use it to implement xBR scaling on DirectX 6
The Longest Journey (Demo) I could get it to work with forced resolution but ther are problems with the zbuffer and Texts are not upscaled correctly yet, i'll try to fix it on the weekend. DirectX 5
Neverwinter Nights(Demo) Doesn't work, you can't even browse textures. The game uses wglSwapLayerBuffers to swap buffers and that function is not hooked yet. Implementing the hook will probably solve the problem
Star Wars: Knights of the Old Republic This one is Direct3D 8 (or 9). Not supported yet
MechCommander 2 Doesn't work. This one does some things on windowed mode before going fullscreen and that is why it crashes
Outlaws The texture fix was broken, but is fixed now
Thandor: The Invasion The demo has a 16 bit installer and i could not install it
I'll check Battle Isle: The Andosia War and the games on the second post on the weekend
