386 battery issues?
Reply 20 of 22, by jakethompson1
JayAlien wrote on 2024-11-23, 20:44:
jakethompson1 wrote on 2024-11-22, 22:19:
JayAlien wrote on 2024-11-22, 21:31:
Thanks all. So if I'm understanding correctly, I should be able to pull the RTC (I'm assuming this is a socket rather than solde […]
Thanks all. So if I'm understanding correctly, I should be able to pull the RTC (I'm assuming this is a socket rather than soldered to the board) and find one of these non-battery powered chips:
file.php?id=206223&mode=view
and I'll be back to running?
For perspective, Digi-Key has new, genuine DS12C887+ (battery inside) for $16.73 plus shipping. They're in Minn. and you're in Wis...
Thanks, is this the correct one?
https://www.digikey.com/en/products/detail/an … DS12C887/956875
Should be!
That version does not support a CMOS clear feature so it will always work. The "A" version has it, but sometimes boards that don't contemplate a CMOS clear jumper short that pin all the time.
Reply 21 of 22, by JayAlien
Thank you all. I replaced the 92 era chip with a new one from DigiKey and I'm partying like it's 1990 again 😀
The attachment IMG_4266.JPG is no longer available
386sx25 SBP2 2M
P75(486) SB16 8M
P133 S3 Vir DX A64g 32M
P233MMX R128Pro A64 64M
Pii400 TNT2 Live! 128M
P3-1G V5 M80 256M
P3-1.4G R8500 A1 256M
A3200 9700 A2 512M
X6800 X850XT A2ZS 1G
E8600 X1950XTX A4pro 2G
QX9650 3870 Xfi 2G
i7-975 GTX570 Xfi 3GB
Reply 22 of 22, by JayAlien
Quick question - do I even need the barrel battery, or should I remove it?
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
A3200 9700 A2 512M
QX9650 3870 Xfi 2G
